Old 04-02-2009, 02:12 PM
jfitzsi1 jfitzsi1 is offline
sputtering, multiple misfire code, CPS?
2001 grand am 4cyl. Throwing a multiple misfire code and sputtering. What is the likelihood that this is a faulty crank position sensor?
Old 04-02-2009, 08:14 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: sputtering, multiple misfire code, CPS?
Did you try clearing the codes ??
If it was your crank sensor it would probly throw a code for that as well.
Have you checked/replaced your plugs/boots/coils and the ICM ?
Also check that the injectors are firing, and the proper ohms resistance and that the Injector wiring harness isnt damaged.
1999 Grand Am SS 3.4 OHV
Old 04-02-2009, 09:53 PM
The codes have been coming and going. I read that I might not get a CEL for a bad CPS. http://www.automotiveforums.com/vbul...71&postcount=2
Old 04-03-2009, 02:27 PM
This is true, you wont always get a light/dtc.
but I wouldnt jump that far ahead just yet.
As I had previously asked have you replaced anything in the ignition system, plugs/boots/coils/ICM ?
Usualy misfires are from one of those components. If those are tip top shape then start looking at the fuel side of things, injectors/wiring.
Hope that helps
