Old 04-02-2009, 11:49 AM
tleeburks tleeburks is offline
Tires sizes, Can I change
I have a 2000 Ford F150 with 255 70 r16 on it. I found some tires on craiglists with good rims. They are 235 70 r16's. Can I put these on the vehicle? What are the risk etc? Thanks
Old 04-02-2009, 12:58 PM
Torch Torch is offline
Re: Tires sizes, Can I change
Here is a link for figuring out what the tire code on the side of your tire means: http://www.tirerack.com/tires/tirete....jsp?techid=46
But to answer your question...
235mm = approx 9.2 inches.
255mm = approx 10.0 inches.
So you are dealing with a difference of 0.8 inches which is just over 3/4 of an inch, that might be enough to cause some bead sealing problems, but since they are coming with their own rims that won't be a problem.
Something that may cause you problems (if you have driven this truck for a long time) is that the wider the tire is the more grip is has to the road surface and the better handling you will get in corners (to a point) you may feel the 3/4 inch difference or you may not it will depend on your driving style and how well your truck handled in the first place.
Old 04-02-2009, 01:04 PM
thanks torch, its for my son's truck and you know how teenagers are. thanks again.
Old 04-02-2009, 06:20 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
It will also make your speedometer off. Probably be reading about 8 mph faster at 60 than it should.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
