Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-02-2009, 07:48 AM
97copcar 97copcar is offline
drivers window stuck in the down position
I have trouble shot the problem to either the motor in the door or the power window control module. I have already ruled out the switch.
What I want to do is find out the voltage that the window motor uses. If it is the same as the battery in the car, I want to try and bypass everything and run a line to the motor harness and see if the window will go up.
At this point I just need my window up as it is starting to rain a lot here. If anyone has a trick I can use to raise the window, does not have to fix the problem......please let me know.
Old 04-03-2009, 11:44 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: drivers window stuck in the down position
Should be battery voltage.
Old 04-03-2009, 12:18 PM
great, thanks. I just wanted to check so I did not damage anything. hopefully I'll have a raised window tonight.
Old 05-18-2009, 02:11 PM
gdawgdb gdawgdb is offline
Often time a window motor will stick, try taping the motor and it may free up. Of course as always insure you have a good ground.
ROCKIN IROC
Old 05-18-2009, 02:22 PM
It ended up being that the motor had died. I pulled the connector and plugged in a buddies spare motor to test it.
I replaced the motor and everything works great now.
