Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 04-01-2009, 10:38 PM
9_trans_am_3 9_trans_am_3 is offline
Talking 93 trans am runs ruff
hey i have a 93 trans am..runs ruff after about 10-15 min of driving when cold car runs awesome..but after 10 min it starts too run real ruff..so i put new spark plugs,coil...im just not sure what it could be...i was told its probly the spark plug wires..any ideas or suggestions!? thanks.
Old 04-03-2009, 11:30 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 93 trans am runs ruff
Definately sounds like a issue in the ignition system. Check and make sure the water pump isn't leakin gon to the opti-spark distributor right below it.
Old 04-09-2009, 04:44 AM
hossdawg hossdawg is offline
Its your coil control module...ill bet you a hundred bucks.
Old 04-14-2009, 12:48 PM
FormulaForce FormulaForce is offline
My first guess is indeed the spark plug wires, especially the longest ones that go to the rear of the engine. I had a problem exactly like that and that's what it was: the rear-most driver side plug wire (I think that's number 7). Sometimes wires work fine until they get hot. I've had good-looking wires pull apart easily because they were really cooked from the exhaust heat. You COULD NOT tell by looking at them. I put Accel 9000 hi-temp silicon plug wires on and that fixed that. New wires are cheaper and easier than the opti-spark distributor, which may be the other cause. Since you're having problems only after heat-up, it really sounds like a plug wire. Get the best ones you can afford, and make sure they are high-heat rated. Jegs.com has the Accel ones I used.
Tags
350lt1 , firebird , trans am
