Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 04-01-2009, 08:26 PM
Dawgfan Dawgfan is offline
Time to change the Oil
Getting my car tomorrow. Fuel injected Cobra engine. What does everyone use in the engine, transmission and rear end?
Old 04-02-2009, 12:47 PM
eric1h eric1h is offline
Re: Time to change the Oil
Oil, Valvoline 15-50 Race oil
Tranny GM- GM Syncromesh
Rear Diff I usually use Royal Purple 75/90w gear max
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 04-02-2009, 10:11 PM
NZGTRA17 NZGTRA17 is offline
Engine 15-50 Elf Race Semi Synthetic (5.0 engine)
Engine Filter - K & N high pressure
Trans MT90 Red Line full Synthetic
Diff Redline Heavy Weight Shockproof full Synthetic
I have absolutely torture tested Redline in gearboxes and Diffs over the years and swear by it. I have had an input shaft bearing split radially during a meeting (in a 530hp car fitted withn a close ratio Muncie) and was able to complete the meeting without having gear selection or trans overheating issues due to the ability of this oil to reduce friction. I had had this same failure happen previously when using another brand of semi synthetic trans fluid and my race was over within 2 laps due to heat build up melting the bearing outer race.
You can run Red Line Lightweight Shockproof in the trans but I now use MT90 as it is designed to run in synchro box applications.
Kel M
Panoz GTRA #17
New Zealand
Old 04-03-2009, 07:21 AM
Jim woodruff's Avatar
Jim woodruff Jim woodruff is offline
Since the Oil companys have all changed the formula in there oils to go green and they have lowered the zink and phos. content to limits not condusive to race engines. My suggestion is to look at Brad Penn oils. I have lost two engines with other oils in the last year and this oil has been recomended buy a number of engine builders, this is what I am using in both race engines with great results. The oil companys have not told anyone about the changes but look at the reduced times difference between oil changes on the new cars. As a side note Delvac and Rotela have also been reduced.
Sorry for the can of worms.
Old 04-03-2009, 08:01 PM
Thanks for all the info. Will start preping the car tomorrow. Looking forward to racing this year.
Old 04-04-2009, 07:56 AM
David Eastman David Eastman is offline
We need photos.
David
Old 04-04-2009, 07:51 PM
Will get them up this week. David, will you be coming up to R A at the end of the month for the Mitty?
Old 04-05-2009, 08:12 AM
No I'm going to Roebling with the Darkside instead.
Old 04-05-2009, 03:46 PM
Cobrafang Cobrafang is offline
I will be up Sat and Sun. Gary Jones Motorsports is running some cars and I will be a guest with them.
-Cobra (A.K.A Tom D)
Racer and Gamer
Panoz GTRA (Mystery Chassis #) (Track Toy)
2001 BMW M5 (Road Toy)
2006 F250 (Car Hauler)
2002 Odyssey (Kid Hauler)
Old 04-05-2009, 05:58 PM
Have fun at the Mitty and take alot of photos. Turn 10a and 10b are great place to watch. You will see a lot of late braking passes there.
David
