Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-31-2009, 10:01 PM
FF18 FF18 is offline
Front caliper help
Hey all i have a 94 Camaro V6 and im on my 3rd set of rotors in about 50,000 miles. Im pretty sure i found out why my rotors are warping so bad, is because the bottom/leading caliper bolt "pin or sleeve"is stuck and on one side has actually broke. When i replaced them the first time i made sure to use plenty of high temp lube but for some reason they keep getting stuck and causing my brake pads to wear uneven and my rotors to warp as the caliper cannot slide on the bolt sleeve. As i was replacing the caliper bolt sleeves this last time the back side pins went in easy but the front or leading sleeves i had to press in with a c clamp. What can i do to free these up so my caliper can slide. I used plenty of lube but still no luck. The bolt slides through the sleaves with no issues but the caliper will not slide on the sleaves.
Thanks
FF18
Old 04-03-2009, 11:42 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Front caliper help
I've gone cheap on dry pins/bushings and used anit-seeze.
