Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 03-31-2009, 02:24 PM
GreatOnizuka GreatOnizuka is offline
97 neon plymouth
ok so my plymouth was working just fine then i stoped at a SA and turned it off then it would not turn over or start so i opend the hood and say the -cable to the battery was corroted and not attatched to the battery so i rigged it and put the cord under the thing that holds the battery - side and it still wont start the battery works fine i get power to radio and everything else but car wont turn over what could be the problum?
Old 03-31-2009, 02:38 PM
Scrapper Scrapper is offline
AF Premium User
Re: 97 neon plymouth
must have lost it's ground but what your saying on the not turning over sounds like starter may be checked out and also the pos cable was caroaded up that means your alt is puting out more amps than the battery can take. have you took this to autozone and have battery and starter checked? because when you turn starter over it takes power away from fuel pump so have that checked also to see how much psi running on pump.. but if it isn't turning over it has lost it's ground to the motor and make sure your getting power from pos. sounds to me like it's starter or ground to the motor..good luck..
Old 04-01-2009, 06:56 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Clean the cables and battery posts REALLY WELL. Then make sure the cables are on there nice and tight. Loose connections won't start the car.
2003 Dodge SRT-4
Tags
car , not turning over
