Old 03-31-2009, 10:48 AM
montchevyproblems montchevyproblems is offline
94 cavalier elec
I hope somebody can help me, my car started cutting out and then died, then would start again for awhile, but now wont start at all
Old 03-31-2009, 04:56 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 94 cavalier elec
If you want the "full version" of this help, we'll need the engine size.
To start, check the fuel pressure and check for spark. Also, I've noticed that a lot of GM cars have fuel gauges that aren't that accurate. I've had cars come in to the shop that do that, and a tank of gas fixes it. It's worth a try, anyway, especially the way it quit running on you. I've seen the gauge as far off as reading half way between 1/4 and 1/2 when the tank was bone dry.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
