Old 03-30-2009, 09:21 PM
GrandAMSE00 GrandAMSE00 is offline
2000 SE Keyless Entry?
Does anyone know how to program a 2000 Grand AM SE's keyless entry into the fob?
Old 03-30-2009, 11:33 PM
H1HUMMERMAN's Avatar
H1HUMMERMAN H1HUMMERMAN is offline
Re: 2000 SE Keyless Entry?
Transmitter Programming Procedure (Method 1 - No Tools Required)
To program the transmitters, perform the following procedure while seated in the vehicle driver's seat:
  1. <LI type=1>Close all the vehicle doors. <LI type=1>Remove the ignition key from the ignition lock cylinder. <LI type=1>Press and hold unlock on the door lock switch. Important: To successfully enter the keyless entry programming/diagnostic mode, steps 4 through 6 must be completed within 25 seconds of pressing the door unlock switch.
    <LI type=1>While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder. <LI type=1>Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure. <LI type=1>Release the door lock switch. The chime will sound three chimes to signal that transmitter programming/diagnostic mode is active. <LI type=1>Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for approximately 4 seconds. The chime will sound two times to signal that the transmitter has been programmed successfully. <LI type=1>Repeat step 7 for the rest of the transmitters (for a total of 4 transmitters).
  2. To exit the transmitter programming/diagnostic mode perform either of the following:
    Turn the ignition switch to the RUN position.
    Remove the ignition key from the ignition switch.
Old 03-31-2009, 01:14 AM
haha nope
Old 03-31-2009, 09:08 AM
3100 3100 is offline
Banned
see if battery is inside
Old 03-31-2009, 11:50 AM
hehe yep. either your doin it wrong or the only other way is with a tech 2.
Old 03-31-2009, 12:31 PM
doctorhrdware doctorhrdware is offline
Or better yet is the battery good? IE is it dead or the weak, like voltage
is low. This would cause the key fob not to function.
Old 03-31-2009, 01:03 PM
Banned
fob can be bad also (if old), teke it to Autozone they have the small fob frequency tester.
Old 03-31-2009, 02:16 PM
I forgot that the parts places have the testers for the fob.
