Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 03-30-2009, 06:45 AM
charlie carter charlie carter is offline
Question airbag light
I haven't had my 95 estate wagon long,but the airbag light stays on and was hidden with a piece of black tape covering it.Actually just covered probably because they didn't want to look at it constantly.What could cause this?And if they find it's been deployed,will it be reported to carfax?It hasn't so far.
Old 03-30-2009, 12:45 PM
maxwedge maxwedge is offline
A990 racer
Re: airbag light
This must be scanned with an abs function scanner to pinpoint the problem.
Old 04-07-2009, 04:41 PM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Re: airbag light
Your car does require a specific scan tool to find the problem, but here's a site that will explain everything you need to know about airbag lights and resetting the system.
http://www.airbagsolutions.com/
This website gives you the procedure for diagnosing and resetting airbag lights. See if your car is listed here. Although it’s a pay site ($14.95/day), it’s a lot cheaper than going to the dealer
http://www.airbagsolutions.com/vehicles_list.aspx
On most vehicles, the airbag light should come on for @6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident.
The flashing light on your car is telling the answer you need. On some vehicles, the light is flashing a two digit code. Once you know the code, you can most likely repair it yourself. There are fairly easy procedures that most people are capable of repairing.
Airbagsolutions.com has the fault code charts to tell you what is wrong and how to fix it!
Some vehicle manufacturers accommodate systems without a scanner (like Toyota, Lexus, Nissan, Infinity, Honda, Acura, Ford, Lincoln, Mazda & Mercury) and some require a scan tool.
Check out these websites also for more info on airbag systems and the light.
http://blog.airbagsolutions.com/arch...ould-i-do.aspx
Lastly, check your vehicle for recalls through this link also:
http://www.airbagsolutions.com/nhtsa.aspx
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
