Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-29-2009, 06:04 PM
dorkdriver2 dorkdriver2 is offline
Inner tie rods?
Anyone with experience removing inner ties rods on a 95 transport? Do you have to remove the whole rack assembly? Will a tool from Autozone work? Any ideas or tips will be appreciated. Thanks.
Old 03-29-2009, 06:35 PM
yellowfiero yellowfiero is offline
Re: Inner tie rods?
Are you sure its the inners? I just replaced my outers and ball joints.
Old 03-29-2009, 06:57 PM
Re: Inner tie rods?
Ball joints are fine(replaced 2 yrs ago). I just replaced my outers today but there is still a little play at the inners. I haven't done inners before and I'm trying to get all the information that I can. I don't want to damage the rack and prefer not to remove it.
Old 03-30-2009, 10:04 AM
LMP's Avatar
LMP LMP is offline
Re: Inner tie rods?
I replaced my inners once and I did remove the rack... But several other forum members managed to build "special tools" and did the change in situ. there are a few threads about that, will try to find and link.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 03-30-2009, 12:47 PM
96tsport 96tsport is offline
Re: Inner tie rods?
Had an inner done passenger side with a 3.4 engine. Mech did it with the rack in place & wasn't a big deal.
~70k last 3 years with no major issues ~270k total; unknown prior history.
Old 03-30-2009, 03:23 PM
Re: Inner tie rods?
The inner is staked, and that's where I'm not sure if the tool would work. I've seen that tool, and it basically goes over the tie rod itself and onto the end which is attached to the rack. You need to put a wrench on the rack end so you don't torque the rack itself. It'll be pretty cramped - hopefully someone whose done it can chime in.
Old 03-30-2009, 06:21 PM
Re: Inner tie rods?
I only mentioned my job in that didn't cost much (& wasn't a huge job) to pay someone to fix.
Some jobs, best thing is to spend a few bucks rather than fiddlin away.. & ending up with headaches..
As LMP mentioned, pretty sure there is info in former threads of folks who have done the job & some of the info suggested the rack has to come out. Maybe it does for the 3.8 ..or if not having the right tool(s) dunno.
Probably time for an alignment after too..
Old 04-01-2009, 08:49 AM
Lumina94APV Lumina94APV is offline
Re: Inner tie rods?
Here is a couple of posts on it -
http://www.automotiveforums.com/vbul...d.php?t=642615
http://www.automotiveforums.com/vbul.../t-549451.html
I removed the rack as per the Service Manual - but wouldn't do that again!!
I bought the parts at Canadian Tire and they loaned me the tool... Make sure you hold the rack from turning to avoid damaging the gears.
The Inner tie rod is threaded onto the rack and crimped. I think the hard part is how to crimp the new one so it doesn't come loose. Loctite would be a good idea too.
Allan
Old 04-01-2009, 01:52 PM
Re: Inner tie rods?
Just had a look at the 96 3.4 FSM & it calls out rack removal for inner tie rod service.
Main cautions shown (& these are only for after removal) are:
Notice
- Rack must be held during removal of ITR to prevent rack damage.
Important!
- Rack must be held during ITR installation to prevent gear damage.
Important!
-Make sure tie rod rocks freely in housing before staking ITR assy to rack.
Few other checks involved also during this part..
Old 04-02-2009, 07:34 AM
Re: Inner tie rods?
Allan
Those links helped alot. Thank you. I have the 95, which is the last year of the "Dustbuster" models. It seems I won't have to drop the rack. I'll look at it closer this weekend.
Old 04-02-2009, 08:58 AM
Re: Inner tie rods?
This sounds interesting. If you can, document for the rest of us "noobs" what you did. If you can, take some digital pictures, because I'm sure we'll need them too!!!!
Thanks, and good luck.
Old 04-02-2009, 02:06 PM
LMP's Avatar
LMP LMP is offline
Re: Inner tie rods?
... I have the 95, which is the last year of the "Dustbuster" models. ....
..for the record, 96 was the last Dustbuster year..but gone was the 3.8: 3.4 only .
...and, I wish you can avoid a full removal, as other have been able to, but just in case: www.avigex.ca/xport/rackremoval.jpg
www.avigex.ca/xport/steering3.jpg
Old 04-04-2009, 06:02 PM
Jrs3800 Jrs3800 is offline
Re: Inner tie rods?
Its a shame that 95 was the last year for the 3800 in the U Bodies..
I replaced the passenger side Inner tie rod with the Rack in Place.... It was a living and breathing nightmare... I got it done tho.. It is much easier to deal with the rack on the ground..
Very soon I will have my engine out for a 3800 Series III swap... But at that time as the Miles are high on the van I am going to go ahead and replace the Rack while the subframe is out.. So the new rack is sitting here waiting to go in..
If you have the Money I recommend that you let the shop take care of the inner tie rods.. Ball joints are much much easier to deal with on these vans..
Old 04-05-2009, 10:26 AM
Re: Inner tie rods?
Well, I didn't do anything this weekend. Went out late with the buds last night. Money is tight right now so I'm probably going to put it off for a little while. I'll get an estimate from Lentz and go from there. I've always liked tackling the jobs myself because it saves mucho $$$ and I usually learn alot. I've decided if I have to take the rack out, I'm not gonna do it.
Old 04-05-2009, 03:16 PM
Re: Inner tie rods?
You can do this with the Rack in the van... But it is a Royal PITA... I have done it and would do it again to avoid pulling the rack.. I wouldn't recommend it tho... Once you replace the Inner tie rod the alignment will have to be reset.. So you may be better off finding a good shop with fair prices that can also reset the alignment when they are done..
I have a thing about doing the work myself as well.. I understand..
