Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 03-29-2009, 05:03 PM
sekeraksm sekeraksm is offline
Front Bearing/Hub bolts
I attempted to replace both my front hub/bearings today. Heres the problem, one of the bolts was partially rounded off already, I finished it the rest of the way trying to get the dang thing off. How can I get this bolt out now? Any other suggestions?
Old 03-29-2009, 05:31 PM
ctwright ctwright is offline
Re: Front Bearing/Hub bolts
Ok, after you do this get another nut for it. Take some good visegrips, make sure the longest part of the grips is on the bottom side, and the part you push down on them is on the top side, keep playing with the part you turn on the end until you can get it to where it's tight as can be. Example, turn it clockwise, try clamping the grips, if you can't clamp it, turn it counterclockwise a bit and keep doing this until you get it where you can clamp it but it takes alot of energy to clamp it. After this you need to find a long sturdy pipe that will fit over that long part of the grips that has the adjusting knob on the end. After you do this pull up, hopefully if it's good and tight it won't slip.
You will need a big set of vise grips to do this, you might also be able to try a big pipe wrench instead.
Old 03-29-2009, 05:35 PM
I thought you was talking about the center nut. Just regular visegrips should do the trick.
Old 03-29-2009, 05:40 PM
Which bolts is it exactly are you talking about, are they in a spot you cannot get visegrips on them?
Old 03-29-2009, 05:56 PM
rhandwor rhandwor is offline
I think you might need a damaged remover set. Sears,Napa,and other parts stores carry them.
http://www.ntxtools.com/ Search GPC 2300k
Grey pneumatic corp.
Irwin and Blue point and craftsman make a version of these.
Old 03-29-2009, 06:20 PM
Write back first with which bolts it is. Is it your caliper bolts? You should be able to get it out with some visegrips without buying special removers as long as you can get to whichever bolt you are talking about with ease.
Old 03-29-2009, 07:11 PM
Its one of the 3 bolts that holds the front bearing hub on. its the one on the drivers door side.
Old 03-29-2009, 07:14 PM
Have you tried visegrips?
Old 03-29-2009, 07:22 PM
I've switched between US and Metric six point impact sockets and tapped the socket on with a hammer. Use a propane torch and heat up sometimes they use lock tight.
Old 03-29-2009, 07:30 PM
Excellent advice, that reminds me one time I cut out a section of a soda can and wrapped around a bolt head and then hammered the socket over it and it worked to get the bolt out.
