Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-29-2009, 02:07 PM
1987ss's Avatar
1987ss 1987ss is offline
96 no parking lights
its a 96 thunderbird if you turn switch to parking lights the tail lights work but nothing up front. if you switch it to headligts again just tail lights and headlights no orange markers. checked fuses under hood and the box under driver side dash. when you arm the alarm they dont flash eithor just tail lights and horn honk. dash lights all work too..ANY IDEAS?
Old 03-30-2009, 08:03 AM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Re: 96 no parking lights
Originally Posted by 1987ss View Post
its a 96 thunderbird if you turn switch to parking lights the tail lights work but nothing up front. if you switch it to headligts again just tail lights and headlights no orangg markers. checked fuses under hood and the box under driver side dash. when you arm the alarm they dont flash eithor just tail lights and horn honk. dash lights all work too
OooooooK
Old 04-02-2009, 09:08 PM
1987ss's Avatar
Originally Posted by JR Tigerstar View Post
OooooooK
must of confused you to?? or ??
Old 04-06-2009, 07:10 PM
97Bird's Avatar
97Bird 97Bird is offline
First thing-Have you checked the bulbs to see if they are ok and the sockets make a good tight connection to them? Do your front turn signals work and are they bright? The turn signals use a seperate filament so if the lights flash it doesn't mean the filaments for the parking lights are ok. It just means you have a good ground connection to the bulbs.There are three connections and one splice that have to be clean and tight for the front parking lamps to work. The secondary junction block under the dash and to the right of the steering column is the first connection. The second is the 76 pin connector that goes through the firewall in the top far left. The third is the connection at the bulbs. The splice is in the headlamp junction harness in front of the battery. The wires from the four front parking lamp bulbs are spliced together at this point so you can just trace the wires to this splice.
The Original 97Bird
Old 04-11-2009, 06:58 PM
1987ss's Avatar
thanks 97Bird. i just changed out bulbs and turn signal switch... turn signals work the hazzards work but still no parking lights up front.. the horn also quit but un plugged it and tested it and its gettin no power. checked connections they were clean and tight. is there a relay that runs headlights and horn?
Old 04-11-2009, 08:33 PM
1987ss's Avatar
thanks found the light problem chewed wire at the engine side of firewall plug. and the mouse or squerrl left me 3/4 of a inch to work with what gauge are those wires? Thanks for the tips
Old 04-13-2009, 06:16 PM
97Bird's Avatar
You're welcome. I'm glad you found the problem and can fix it easily. I'm not positive but they are probably 16-18ga. Put a piece of shrink sleeve over the wire and far enough down the wire so that when you solder the connection, the sleeve doesn't shrink. Once you have the connection soldered then slide the sleeve over the joint and heat it to make a water tight seal. Sometimes a hair drier on high will work to shrink it.
The Original 97Bird
