Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 03-29-2009, 02:04 PM
nick8519 nick8519 is offline
Question Starter "Dragging"
I have an 06 Impala LT 3.9L. when starting car with factory remote start i notice that sometimes as the car is trying to start, the starter will "drag" or the starter keeps turning and the car starts hard. I had a 05 Malibu and i noticed it would do the same thing sometimes. It is only an occasional problem so right now im not going to waste my time taking it to the dealer so they can tell me "We cant replicate the problem"
Any thoughts???
Old 03-29-2009, 02:33 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Starter "Dragging"
I've had a similar issue in the past with my 2006 Uplander with the 3.5 ( factory remote also.) My starter would seem to drag or will keep turning after the key is turned. This does not happen all the time, rather "once in awhile". Below is a quote from another one of my posts (from the Uplander forum) where another member was experiencing a similar issue.
Originally Posted by '97ventureowner View Post
It is normal and is part of the "Computer Controlled Cranking System". It is meant to protect the electrical system while it assists in starting your vehicle.When the key is turned to the "Start" position and released, the engine starts to crank and will continue cranking until it starts, or 15 seconds thereafter, the maximum cranking time allowed to prevent damaging the starter.It also prevents accidental starting of the engine ( damage to the starter gears)while the engine is currently running,( a good thing ). To stop the engine from cranking, simply turn the ignition switch to the "lock", or "accessory" position.
Your vehicles may also have this "Computer Controlled Cranking System" to protect the starter. If you go through your owners manual for your vehicles there should be something listed in there if that system is used on your cars. There is a paragraph that explains about it and says what you are experiencing is normal operation.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
