Old 03-29-2009, 12:21 PM
Micah_Jones Micah_Jones is offline
Help with brakes
Ok I have a 91 Stealth base. The rear brakes are locked up and extremely rusty. I want to just replace all of the brakes. I will need all new everything, calipers, rotors, pads, etc. The first thing I wanna know is, what tools will I need to remove the old brakes, and put on the new ones? Will this be a project too tough for me to attempt? I do not drive the car right now, so time is not a problem. Also, where is a reputable, CHEAP place to get this stuff? I would like to keep it under 500 bucks for all 4 brakes, which I dont think is possible, but Ill stay hopeful.
Old 03-29-2009, 12:39 PM
quackmandude quackmandude is offline
Re: Help with brakes
u want stck brakes right? ull need a 17 mm wrench or socket to take off the braket with the brake pads if im not mistaken. then to take off the cailper u just disconnect the brake line. remember after u finush ur gonna have to add fluid and bleed the brakes so be sure u no what ur doing. anye the cheapest place?
SAMSUNG-SGH-I617/1.0 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.6) UP.Link/6.3.1.17.0
Old 03-29-2009, 01:03 PM
vr4choke's Avatar
vr4choke vr4choke is offline
Send a message via AIM to vr4choke Send a message via MSN to vr4choke
you can get all the parts from 3sx. itll run you closer to 1k though
Old 03-30-2009, 06:30 PM
Igovert500's Avatar
blue + red light magnet
You can take it all off in your driveway at home with a jack, some stands, and any basic wrench set. i would however recommend investing in an 18" pipe that fits the end of your socket wrench handle (for extra leverage) and a bottle or 2 of PB blaster...both will make dealing with the rust significantly easier. As far as difficult, they aren't, but our brakes are a tiny bit more complex than the average grand am or something...if it's your first brake job, just ask someone who has done a brake job before for some help. If you can't find someone, check out stealth316 or vr4stealth.com (links are in the faq) both should have pictured instructions. Rule of thumb: do one wheel at a time, that way if you get confused you can always look at the other side. As far as parts, pads can be found relatively cheaply for half decent ones...I think my Stillen metal matrix pads were like $120 for the whole car iirc. Rotors are gonna run you a bit more, but if you run a search on here or 3si, you can usually find the places that you get a decent product for a good deal. Just remember when you are stopping from 100+ you can appreciate the saying: a good product isn't cheap, and a cheap product isn't good. Brakes are one of those things where quality should definitely be a factor in your purchasing decision.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-30-2009, 07:38 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Most definitely sound advice Igo.
The cheap abay rotors should be avoided. Leet on 3si had one break around the rotor hat while running the ring. He has the event on an in car camera.
Needless to say stopping was quite difficult.
Old 04-03-2009, 06:49 PM
Well, I am not even sure if my car in its current state would do 100, nor do I wanna find out . I just need brakes that will work for every day braking, nothing extreme, maybe from 75 off the highway or so. Will they work for everyday driving? (the cheap fleabay ones)
Old 04-03-2009, 10:14 PM
dont go ebay regardless, get the brembo blanks u can get a pair for 115 if im not mistaken. someone give hima link cuz im on my blackjack
SAMSUNG-SGH-I617/1.0 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.6) UP.Link/6.3.1.17.06.3.1.17.0
Old 04-04-2009, 08:43 AM
Stealthee's Avatar
Definitely dont use use ebay.
Brembo blanks are getting harder to find. There was a post on 3si about them no longer doing aftermarket OEM stuff anymore.
Auto parts stores blanks will serve you fine for every day use.
Old 04-14-2009, 09:37 AM
Crackhedbob341's Avatar
Crackhedbob341 Crackhedbob341 is offline
My friend just bought 4 Hawk brakes and drilled/slotted rotors for 300. If you haven't already done this, I can send you the link later.
You also need a C clamp to compresses the pistons before you finish.
Never bring show to a go fight.
And a TT conversion brewing..
Old 04-14-2009, 10:26 AM
stay away from drilled and slotted unless your seriously racing/showing your car. unless u dont mind buying new rotors eveytime they warp. blanks will be fine, and when u compress the pistons besure to do it slowly
