Old 03-28-2009, 10:20 PM
shadetreeh shadetreeh is offline
Unhappy 1985 f150 no spark help
85 6cyl standard 4 by 4 we have replaced the coil, computer ,icm,, pickup coil condenser fire goes into coil but does not come out what is wrong
Old 03-28-2009, 10:26 PM
ctwright ctwright is offline
Re: 1985 f150 no spark help
You say fire goes into coil? Generally when talking about fire we are talking about the spark, not voltage to the coil. So do you mean you are getting voltage to the positive side of your ignition coil or do you mean that the center wire on the distributor has fire when pulled loose from the distributor cap and checked(would mean you have fire coming out of the coil). If the latter then take off the distributor cap and check the rotor button. If you are getting voltage to the positive side of the coil and you've already replaced the icm and ignition coil coil I would suspect you need a crank position sensor. Check to see if you are getting ground pulses to your negative side of the coil while turning over the engine. If not then it's probably the crank sensor seeing how you've already replaced the ignition module and ecm.
