Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-28-2009, 08:39 PM
snt0710 snt0710 is offline
Question 95 eclispe gsx: will a exedy FWD clutch work with AWD?
I have a 95 eclipse GSX with the 4g63t engine from a 91
i have a fidanza 9lb flywheel and an exedy stage 1 clutch but it is for FWD
I looked at specifications on the FWD and AWD exedy clutches and only found a difference in the torque capacity: FWD: 245 lbs/ft and AWD: 230 lbs/ft both specify a disc size of 225mm and teeth/diam 20T/ 22.4
Will this work with my AWD, if so what problems/damage may it cause?
This is my first car to rebuild
Old 03-28-2009, 08:47 PM
steviek's Avatar
steviek steviek is offline
Re: 95 eclispe gsx: will a exedy FWD clutch work with AWD?
there shouldn't be any diffrence between clutches but there is a difference between flywheels.
also I had an exedy clutch and it went really fast but I drove the crap out of it.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 03-28-2009, 10:03 PM
Okay thanks. Hopefully i will get to drive the hell out of mine, once i put it all back together
Old 03-29-2009, 10:26 AM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Actually there are differences in clutches in FWD and AWD. I know for a fact that the stock clutchs have two different part numbers from the factory. The AWD versions seem to be a little more heavy duty. In all reality it really shouldn't really make a difference especially if your getting an aftermarket one like the Exedy.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
