Old 03-28-2009, 07:07 PM
tleeburks tleeburks is offline
ABS won't shut off 2003 S-10
I have a 2003 Chevy s-10. I recently went to get gas and went to drive off and the ABS turned on and starting humming. I finally unplugged it for it was annoying and it was running the battery down. Any help? suggestions? thanks
Old 03-29-2009, 09:43 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: ABS won't shut off 2003 S-10
You need to pull codes on a ABS capable scanner and post back codes.
MT
Old 05-10-2009, 09:29 PM
sparky11 sparky11 is offline
i have a similer problem and i got a right front wheel speed sensor circuit open code how do i fix the sensor and where exactly is it on the wheel assembly
Old 05-11-2009, 11:12 AM
MT-2500's Avatar
AF - Advisor
Circuit open is usually wiring or wiring circuit open.
Check wiring to sensor and ABS computer.
On your problem best to start a New thread.
Saves on hi jacking another persons problem.
MT
