Old 03-28-2009, 05:55 PM
cabron1 cabron1 is offline
2000 sel windstar: Front speaker install
Folks,
My front ( door ) speakers are blown. I bought some 6.5 " speakers. How do I get to the speakers to replace them. Do I need to take the door panel off? Can I get at them by removing the grill ( don't know if the grill is removal).
I will appreciate all advice. I don't want to F%#@ it up.
Thanks
Old 03-28-2009, 06:36 PM
mundy5 mundy5 is offline
Re: 2000 sel windstar: Front speaker install
Here is what the FSM says about it.
REMOVAL AND INSTALLATION
Speakers — Door Mounted
Removal
1. Remove the door trim panels (239420). For
additional information, refer to Section 501-05.
2. Remove the speakers (18808).
1 Remove the screws.
2 Disconnect the electrical connectors.
3 Remove the speakers.
To remove the door panel follow these instructions
Trim Panel — Front Door
Removal
1. Disconnect the battery ground cable. For
additional information, refer to Section 414-01.
2. Remove the window regulator control switch.
3. Remove the door handle escutcheon.
4. Remove the mirror access cover.
5. Disconnect the electrical connectors.
6. Remove the front door trim panel screws.
7. Remove the front door trim panel.
8. If equipped, remove the courtesy lamp.
2003 Windstar LX
1998 4dr Civic LX
Old 03-28-2009, 07:05 PM
wiswind wiswind is offline
If you look at the pictures that the link in my signature takes you to.....you will see pictures that show how to remove the inner door trim panel.......it is on my '96, but your 2000 should be close enough.
The "grill" is part of the door panel on my '96.
If you visit the Crutchfield site.....they will tell you what speakers will fit without having to do any modifications.
That is in their online catalog.
If you buy from them.....they send installation instructions for your particular vehicle....including how to remove the trim panels.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
