Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Non-Performance
Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications.
Old 03-28-2009, 01:47 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
2000 cavalier antitheft?
hey guys i was just wondering if 2000 cavaliers had any sort of antitheft system that engaged when the stock radio was removed. we are looking to replace the stock one for a short time and need to put it back in eventually. thanks
Old 03-29-2009, 12:20 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 2000 cavalier antitheft?
If you have the owners manual, take a look in there, they say how to enable and disable the anti-theft. If nobody ever enabled it, they are off by default. If it's got the flashing light on the front, the anti-theft was enabled.
I did a quick search, and found http://www.radio-code.com/GM-Pay-Page-radio-code.htm. DO NOT pay them for that "code" you can get it for free at lots of places, just search around (including AF.com). I linked that page so you could see the "RDS" radio, which I believe needs to be unlocked by a Tech-2 scan tool. I haven't had to deal with those yet, but my '04 has one, and I haven't put it onto lock mode the few times I've had the battery disconnected.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-29-2009, 06:12 PM
manicmechanix manicmechanix is offline
Hey J-ri, I think somewhere after 2001 or 2002 the RDS radios are serial II and you don't or can't put a manual code in. The radio will only turn on if it's programmed (or reprogrammed if it's a replacement) for your car's VIN. Nice if it's your original radio and you unhook the battery that you don't have to worry about it being locked out. Not so nice if you want to switch a different radio in lol. I'm not sure when they went to this set up on Cavaliers but most '01 up GM cars I've seen are serial II.
Old 03-31-2009, 07:41 PM
J-Ri's Avatar
That's good to know, thanks!
Old 03-31-2009, 10:23 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Its 2000+ which has em... All GM cars went with the Class II wiring. Only the upper end J's (ls and LS sport, Z24's had that problem with the codes)
There is a sticky at the top of this section with all the information about this issue enclosed.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 04-01-2009, 10:51 AM
Do you mean that only the pre-2000 upper-end models had the theftlock radios? So are all 2000-up even base model radios are serial II?
I wanted to check that sticky out. Is it in the Non-performance section or what and what's the sticky's title? I can't find it.
