Old 03-27-2009, 05:39 PM
597GTP 597GTP is offline
02 gtp ect location
Does anybody know where the electronic coolant temperature sensor is located on the 02 grand prix gtp?
Old 03-27-2009, 05:44 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 02 gtp ect location
Below the thermostat housing on the lower intake manifold. Just follow the upper radiator hose towards the engine.
Timeslip 08/12/06
AF Community Guidelines
Old 03-27-2009, 05:50 PM
ok, im going outside now and try to find it. Does it have any wires going to it?
Old 03-27-2009, 05:53 PM
BNaylor's Avatar
Yes. A small wiring harness and typical GM electrical connector.
Timeslip 08/12/06
Old 03-27-2009, 08:24 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
If you replace it due to failure, make sure and clear the DTC that was stored or else the PCM wont know the problem has been repaird.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 03-28-2009, 01:42 PM
What is the
"DTC"....
Old 03-28-2009, 01:45 PM
BNaylor's Avatar
Originally Posted by 597GTP View Post
What is the
"DTC"....
Diagnostic Trouble Code
Are you getting a SES/CEL light (check engine) or why are you looking at an ECT? What problem are you having?
Timeslip 08/12/06
Old 03-28-2009, 02:47 PM
My temperature gauge is going up only 1/4 of the way..
and I read somewhere here to change the tstat and the ect and should solve the problem. Now how do I clear that DTC?
Old 03-28-2009, 09:19 PM
BNaylor's Avatar
I see. I'd do the thermostat first. Plus you know you can check resistance of the ECT with a multimeter (DMM) and check calibration based on temperature. That way you don't have to waste money.
What DTC was it? DTCs can be cleared with an odb-ii scan tool or it will clear after a few drive cycles without doing a reset.
Timeslip 08/12/06
Old 03-28-2009, 10:18 PM
tblake's Avatar
In God We Trust
I agree with Bob, My track record isnt so good with replacing parts that arent bad yet. If it aint broke, dont fix it.
Just replace the T-stat. On the 3800, the PCM and temp guage both get their readings from the same sensor. If there sensor were bad, the PCM would set a DTC and the check engine light would illuminate. If your not getting an SES light, dont worry about changing the ECT sensor. Besides its sort of a pain in the butt to get to on the 3800 anyways.
Old 03-29-2009, 11:09 AM
BNaylor's Avatar
Originally Posted by tblake View Post
I Besides its sort of a pain in the butt to get to on the 3800 anyways.
That is true Tim. That left side wishbone engine mount bracket gets in the way and depending on what tools you have it should be removed to make it easier. Also, if ECT is replaced do not use plumber's tape on the threads. Still best to check the resistance just in case. We have the specs in old/archive threads.
Here is the chart:
ECT Calibration Chart 3100/3400/3800
Timeslip 08/12/06
Old 03-29-2009, 11:24 AM
tblake's Avatar
In God We Trust
I was lucky enough to be able to loosen the wishbone bracket on the motor and just slide it out of the way. Then I had to use a wrench to get ect sensor out of there (19mm I believe). No matter what I did I could not get a socket on it due to the angle (not like the 3100).
