Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 03-27-2009, 06:25 PM
spliceman spliceman is offline
Overdrive light
My 02 Mountaineer is going to 3000 rpms before shifting out of first, all other gears seem to shift ok. After about 10 minutes of driving the
overdrive-off light blinks. Any ideas??
Old 03-27-2009, 08:46 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Overdrive light
Could be as simple as a bad speed sensor in the transmission. You'll need to get the codes read though to narrow it down better. Since the O/D light is flashing, you'll probably need to have the transmission codes read rather than just the powertrain codes. Typically, the free code scans only access the powertrain codes.
-Rod
Old 03-27-2009, 09:18 PM
Re: Overdrive light
The o/d light is flashing continuously, there doesnt seem to be a patern. Also if I buy a code reader will that give me the codes I need?
Old 03-28-2009, 10:34 PM
shorod's Avatar
SHO No Mo
Re: Overdrive light
Nope, you'll need to find a scan tool that can access the transmission. Most of the time, this feature is only available on the professional (ie: expensive) scan tools such as what the dealer uses, the Snap-On tool, or the OTC and its rebadged clones.
-Rod
Old 07-25-2009, 06:17 PM
Re: Overdrive light
Sorry I havent posted my solution. Still burning for having to spend $2100 on the tranny getting rebuilt.
