Old 03-27-2009, 05:04 PM
597GTP 597GTP is offline
02 GTP Need help!
New to this , but I was checking my spark plug wires today, and the wire came off, but the metal tip that snaps into the spark plug broke and stood on the plug. can I just pop it back in the wire or do I need a new wire?
Old 03-27-2009, 05:17 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 02 GTP Need help!
You need a new set of wires. Probably best to change out the plugs too while your at it.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 03-27-2009, 05:25 PM
Thanks dude, just wanted to double check. Also wich plugs and wires do you recommend as un upgrade? 74000 miles 02 gtp stock
Old 03-27-2009, 05:40 PM
Bummer...
Old 03-27-2009, 08:22 PM
tblake's Avatar
In God We Trust
GTP? Ever plan on upgrading to a smaller pulley? If so a lot of us run autolite plugs. Might be a good time to throw in a set of colder plugs if your planning on modding. I'm running autolite 605's and they do just fine. They are one range colder.
If you plan on sticking to stock I would recomment ac delco 41-101 iridium or its NGK counterpart (not sure on the part number off the top of my head)
Dot replace them with bosch, and its probably a good idea to use standard ac-delco wires.
Old 03-28-2009, 06:20 AM
KX2000GTP KX2000GTP is offline
but becareful with anything other than delco or autolite copper plugs. copper is the best for even heat displacment which is very imp in our cars esp if you plan to mod. don't go with that split fire crap or bosch stuff either...
I run 3.4 and autolite 104...and you DON'T need special wires...the stock wires will get you far into the modding process...
Good Luck
Old 03-28-2009, 12:44 PM
BNaylor's Avatar
BNaylor BNaylor is offline
For a stock GTP I'd go with the NGK TR55IX Iridium. Thats what I use in my Regal GS. Good cost versus the Delco counterpart. Also, the NGK TR series copper core (TR55 V Power) work fine too. I use the Autolite 103 copper core in my GTP for obvious reasons.
Note: The recommended AC Delco replacement spark plugs are the 41-101 which are Iridium. Made by NGK for GM.
Timeslip 08/12/06
AF Community Guidelines
Old 03-28-2009, 01:37 PM
Thanks for the replies guys...im going to start buying the stuff for my tune-up!....
