Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 03-25-2009, 07:08 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Shifter cable adjustment
I am working on a 1st gen Dodge Neon (not quite sure of the year) and I replaced the Shifter cable because it broke, does anyone know how to adjust the cable, cannot get the tranny to go into park - I have to slam it forward for it to go into park or else I cannot start it.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 03-25-2009, 01:32 PM
Godofwarmike's Avatar
Godofwarmike Godofwarmike is offline
Re: Shifter cable adjustment
i believe you adjust it on the transmission under the passing gear lever the gear position lever is. if you loosen the bolt you can turn the lever to adjust it. not 100% sure though.
1999 Purple Plymouth Neon SOHC Automatic
Bought Feb 2009 For $700
125,000 miles
Maybe the world record for car with most hidden zip ties
Old 03-27-2009, 06:11 PM
denisond3 denisond3 is offline
I would drip some ATF onto the point where the shifter rod enters the tranny too. It may have gotten corroded and is stiff.
Old 03-28-2009, 12:07 AM
I figured it out, you have to remove the center consol and unclip the adjuster on the cable then move the selector to PARK and then make sure the transmissioniin PARK clip the reconnector the detent clip. but thanks anyways guys.
