Power Brake Booster Check Valve?
My brake pedal started going to the floor,no leaks new brake pads a few mouths ago.
I replaced the master cyclinder with a new one not rebiult. I bench bleed it, bleed from farest the the closest 2 times. adjusted back brakes . It still goes way down,almost to the froor.I can push the brakes to the floor in drive and the truck will move , the brakes will not hold the truck back. could it be the check valve ?? I dont hear it hissing, or anything. when I press down on brakes it will have a very slight change in engine idle, not much.
Re: Power Brake Booster Check Valve?
What is your year, make, engine, etc? Are you getting a brake warning light on your instrument panel? Does it take alot of pedal pressure to get it to bottom out?
The check/combination valves could be faulty or clogged with debris, causing them to not close & seal properly. Steady pressure on the pedal that causes the it to slowly sink to the floor indicates a system leak. Also, if the system hasn't been flushed in a while, do so. Brake fluid is hygroscopic, absorbing water over time. You can bleed it many times, but if it is still weak or spongy, then the right procedure isn't being followed or there is air in the ABS system. Autozone has a check procedure for the brake booster: Vacuum Leak Test
System Operation Test
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
1989 C1500/chevy 350/auto/not getting any lights,it started going to the floor sitting at a light one day, I looked for leaks, found none.I replace master cyclinder.no more going to the floor, as far as when sitting at a light or just sitting with foot on brake.
But it seens to go down very far to me, like if it has very thin pads and very thin rotors and drums, which it dont. rotors and drums are good and thick, good and thick pads. Could just be me, I have been driving a 2001 Blazer for the last 5 years, with 4 wheel dics brakes. maybe iam just not used to the old school brakes. I just dont think there working as good as they should, Like I said, when I put the brakes on and stand on them, and give it gas, it will let the truck move, when I was a kid , thats how we burned the tires off dads truck, ( sorry Dad),it wont break the tires loose unless I goose it then it will.I would think it should not let the truck move forward with me standing on the brakes hard? I pull a 16 foot trailer with this with 3 quads on it, and need to stop , no traler brakes to help. Yes I did flush all the old out and have all new prestone fluid. My brother has same truck and he drove mine and said, yes yours isnt near what mine is, I drove his, his stops way better and has alot better pedal. we swamped out check valve , no diff. bleed bleeder @ ABS under master cyclinder. Last edited by steveb2001ZR2; 03-27-2009 at 08:39 PM. Reason: update |
