Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-24-2009, 01:05 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
Need repair advise, please
OK, we happen to have 95 Eclipse with what they call Secondary Air Valve, also known as pulsating air injection solenoid, or air pump. it is Dodge's implant into Mitsubishis, for short time, as it was so much trouble they discontinued it right away.
It is a black valve with solenoid and diaphragm, connecting exhaust and air filter box, just below the filter box. purpose was to pulse extra air into exhaust, to provide final fuel afterburn.
anyhow, it is shot. as a result, we have CEL up, and bad readings of O2 sensor. sensor replaced saturday.
I cleaned this valve yesterday, it was full of water and gunk. same time I found that diaphragm is all kinked. those valves are known to freeze winter time, damaging diaphragm and blowing the solenoid fuse.
as a result, I was told that car will not pass emissions like this.
DAMN PIECE OF PLASTIC IS $372 PRE-TAX.
I need good repair suggestion, or how to fool ECM into not throwing the error code.
Old 03-24-2009, 04:32 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Need repair advise, please
Could try to find a cheap used ECU from one that did not have the secondary air valve. Then it wouldn't be throwing the CEL because it never needed that valve to function properly...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-24-2009, 10:18 PM
ukrkoz's Avatar
that is, actually, a good idea. I doubt I'll find it for less than that solenoid worth, though. We had to replace ECM on my son's 94 eclipse, and it was $1200 pre tax new. at that cost, even junkyards won't sell it cheap.
I'll start with looking for solenoid. junk yards. might be a problem, as dealership pulled those on the screen and told me that there are only FORTY of those eclipses in the country. it was some dumm ass Dodge experiment....
Old 03-25-2009, 03:35 AM
You should be able to pick up an ECU for much much cheaper than that. Any 95 or 96 ECU of the same model (I'm assuming 420a motor? RS and GS) should work for you and not have that dumb solenoid setup. (It looks like there may be some differences in the 97-99 ones)
If you do the whole ebay thing, there are two on there specifically from 95's for a lot less. One is $76 and the other is $99 with the buy it now options... Or you could check with some junkyards and possibly find it cheaper. Just a thought though... Hopefully you can find a cheaper solution than buying a new solenoid for it!
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-25-2009, 10:22 AM
ukrkoz's Avatar
yes, it is GS, 2.0, straight four banger. it's a toad, but it starts and goes, and he's student now.
Black, most appreciate your help. 100 bucks for ECM is a much better solution indeed. I'll look into it tonight. Most greatful.
Good gods, we had 4 Mitubishes so far, and all of them fine vehicles indeed. Except 2 things: razor sharp edges on sheetwork and lord save you from being forced to buy something from dealer. I think them and lexus are in competition on who will make it more complicated and expensive on parts. HONDAS, HONDAS, AND HONDAS.
Old 03-25-2009, 12:47 PM
steviek's Avatar
steviek steviek is offline
if this is all to get rid of the cel just to pass e test why don't you clear it right before the test and not give a chance to comeback on before the test is done? not many people around here care about the light being on im surprised they are so concerned with it where you live.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 03-25-2009, 01:26 PM
ukrkoz's Avatar
it is not that easy.
1. CEL does not go away even after several attempts to clear it with battery disconnection.
2. they stick code reader into the OBD port here. thus, as it throws emission codes, it'll not pass. this particular car is odd - it has something that LOOKS LIKE OBDII port, yet it is not, but I am not guaranteed that emission people here don't have adaptor for it.
it is not ridding of the light - I can pull the bulb out. It is ridding of the codes.
Old 03-25-2009, 04:44 PM
Yeah, I believe that replacing the ECU with a non solenoid one will eliminate any chances of the code appearing for you during inspection. Hopefully... Good luck with it. Lemme know if ya need help finding anything else.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-25-2009, 05:18 PM
ukrkoz's Avatar
Thanks, BC.
I have contacted 3 sellers on ebay. I have to have one that was tuned for eclipses that were built after june 1995, that's when they stopped doing that solenoid.
Old 03-25-2009, 09:01 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Wow, can't believe they won't let you pass because of the CEL. Most garages around here will let me slide on just about everything. The one time I was even running an open downpipe.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 03-29-2009, 02:20 PM
ukrkoz's Avatar
I got it fixed. As usual, it was combination of silly little things. Good I did not buy any ECUs, he-he.
Anyways, yesterday, I was replacing valve cover gasket, a notorious leaker on Mitsubishes.
Same time, cleaned EGR (full of crap, as usual, even at just 70K miles).
While I was on it, I pulled that secondary air valve out again. Basically, it has a solenoid operated diaphragm that opens by solenoid and lets some air back into exhaust in pulsating manner, that's why it is also called PAIR valve - pulsating air injection recirculation.
You can see diaphragm edge through the pipe that goes towards the air filter box. I, simply, pried its edge up and dropped a screw into the hole, to jam the diaphragm slightly open. When we started the engine, and I placed my hand on the hose running from valve to exhaust, I could feel definite pulsation in it, telling me that we have air stream.
CEL stayed.
Well, I was checking on possible oil leaks around the cover gasket today - and, to my surprise, found that O2 sensor plug disconnected itself from the harness. Clip that was supposed to secure it in place was already missing. Now, it is all securely tight together with g'ol duct tape.
CEL IS GONE.
Old 03-29-2009, 04:34 PM
Awesome! Great news to hear man. So much better than spending any money on anything at all. lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-29-2009, 06:22 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Very nice. Duct Tape is the winner. I have a couple connections being held together with zip-ties because those little plastic clips always break by me man-handling it.
And every emissions place will automatically fail you if the CEL is on... no matter what it's for.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
