Old 03-24-2009, 11:57 AM
quackmandude quackmandude is offline
gonna dyno, what should i expect??
im gonna dyno my 94 sl. my list of mods r, full exaust (straight pipe with a resonator from a truck and 2 magnaflows), custom y downpipe, ram air intake, no headers, and a 75 shot. i no every cars different but what should i expect more or less with the nitrous? 250 maybe??
SAMSUNG-SGH-I617/1.0 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.6) UP.Link/6.3.1.17.0
Old 03-24-2009, 02:33 PM
vr4choke's Avatar
vr4choke vr4choke is offline
Send a message via AIM to vr4choke Send a message via MSN to vr4choke
Re: gonna dyno, what should i expect??
im not even gonna try to answer your previous question. . . because im an idiot . but what kinda of nitrous system are you running? wet? dry? i havent seen alot of 3ss with N2O.
Old 03-24-2009, 02:41 PM
dry, wanna sta safe and i gotit for free
Old 03-24-2009, 10:42 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Wet shot is safer.
I dont think you will touch 250whp. I would venture to guess around 225 with spray.
Old 03-24-2009, 11:54 PM
vr4choke's Avatar
free?! i want free NOS. . .
Old 03-25-2009, 12:43 AM
yep it was a friends, is wet really safer??? yea 225 sounds decent iguess
Old 03-25-2009, 01:01 AM
vr4choke's Avatar
without supporting mods, neither one is exactly safe. with a dry system, its good to have an upgraded fuel system ie: injectors, pump, FPR(since the stock one can't support a high enough range of pressure) .but since 3ss are MAF, you'll probably be fine without an FPR. its also harder to control the a/f ratio with a dry kit (just like how its easier to control fuel with direct injection), which could lead to trouble. on the stock fuel system theres a good chance you could end up lean since the injectors and pump wont be able to supply enough fuel to compensate. what are u using for delivery?
Old 03-25-2009, 11:15 AM
what do mean delivery? its a 75 shot zex dry system?
SAMSUNG-SGH-I617/1.0 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.6) UP.Link/6.3.1.17.06.3.1.17.06.3.1.17.06.3.1.17.06.3.1.17.0
Old 03-25-2009, 02:31 PM
vr4choke's Avatar
are you just using a fogger to spray it past the MAF? that would be the typical setup for dry, but i wasnt sure what u were doing
Old 03-25-2009, 03:04 PM
no i beileve we r installing a jet before the maf
Old 03-25-2009, 06:44 PM
vr4choke's Avatar
thats what i meant. when i said "past the MAF" i meant that the nozzle would be before it so that when it sprays it passes through the sensor. i just worded it kinda stupid.
but anyway, like that you will probably be fine. if you were on turbos then youd probably be lean because the stock fuel system wouldnt be able to balance out the increased air from both turbos and that needed for the NOS. since you have an SL though i think it should be ok.
but wet is actually safer, since its easier to control. if you use the method we just talked about with the MAF sensor, then it just tells your computer that more fuel is needed, due to the colder, denser air from the N2O, and the fuel system does its best to supply what it determines as the needed amount. but it isnt really that precise. if, however, u use a wet system (particularly direct port) you can control EXACTLY how much nitrous and fuel is going into each cylinder.
you could probably find a wikipedia article that would explain all this a little more clearly
EDIT: found one!
http://en.wikipedia.org/wiki/Nitrous
alot of that is way more technical than you probably need/care to know, but it cant hurt...
Old 03-25-2009, 08:43 PM
thanks man that helps out alot!
Old 03-25-2009, 10:34 PM
vr4choke's Avatar
no problem bro. i'm totally psyched when someone asks a question i can actually answer. usually im the one full of questions
Old 03-25-2009, 11:10 PM
lol yea ima mechanic but ive never messed with nos so this is my first time
