Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-24-2009, 03:32 AM
deathdoakill deathdoakill is offline
97 standard with 99 automatic engine
sorry guys new to this forum not to familiar with the eclipse engines I recently bought a 97 (manuel) the previous owner had an engine from a 99 (automatic) put into it 72k it hasnt been started it has no fire to the plugs fuses have been checkd all good car just bought today someone was saying since it came with the original automatic tranny that theres an issue wit ecu since it still has the one from the manuel tranny in it have both ecu's but dont know if this true.... or crank/cam senser would be a reason for it not haveing fire .. and wiring pigtails as well but i was under the empresion that these engines were interchngable hmmmm.... some help would be apreciated im gonna try to get this car up an running soon as my cougar is now in need of an engine an frnt bearing dammed cugas or should i invest in getting a new engine an starting over on this eclipse i need to do a compression test as well but havnt got to yet im not as clueless as i sound just looking for a place to start thanks again guys
Old 03-24-2009, 10:38 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: 97 standard with 99 automatic engine
Welcome to AF.
Please you use proper punctuation when posting. I tried reading it but got annoyed trying to decipher what was being said. Please repost so we can help you out.
Also, what model are we talking about (turbo or non?).
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-24-2009, 11:49 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
And plesse use the correct sub forums. I moved this from the tech articles earlier.
If you just swapped the motor and not the tranny then their shouldn't be any issues. So you are getting fuel but no spark? Are you getting power to the coil?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-25-2009, 01:11 AM
hey sorry about the lousey spelling. I have a bad habbit of not sleeping an even worse not checking my puctuation. It is non turbo he kept the original trany from the 97 no power to the coil, have not been able to really work on the car or take a more detailed look into what was done yet. the guy showed up without his name on the title so im waiting on the one whos name is now on the tittle now so we can make the bill of sale official. the engine did run at one point when it was in the 99. It was turned and he ran it for a while before doing the engine swap. After he couldn't get it started again
Old 03-25-2009, 03:14 AM
oh and i havn't done the fuel system presure test yet but i have all the gauges and plan on doing so soon as i can on thursday. Do you think it could be the ecu i heard him mention something about the ecu being bad at one point talking on the phone, come to think of it he couldnt put the one from the 99 as he said the plugs were differnt hmmm.... would that keep it from getting power to the coil.
