Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-23-2009, 09:39 PM
frank58 frank58 is offline
2001 Mustang 3.8L random miss
130K No cats, no sims , new wires and plugs the old plugs were clean and normal. Fuel pressure 50psi, have road tested will miss randomly at idle-or under load. Will stop if AFS is unpluged but will come back. Its a new AFS. Check air bypass, EGR and replaced eletronic control sensor for EGR. Cleaned throtle body. Vacume reading 17in. Motor has a squek. Have removed belt to try and find squek. Sounds like lifter area. Will do compression test next.
Old 03-26-2009, 09:54 PM
Re: 2001 Mustang 3.8L random miss
PCM had chip in it for many years. Removed chip and all is well.
