Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-23-2009, 02:11 PM
jack1018 jack1018 is offline
96 front struts squeak
Hi, My wife's 96 transport has developed a squeaking noise when the wheels are turned. It sounded like the top isolator pad of the struts are rubbing on the mounting plate. What can be done to fix it or is it even a concern? Thanks
Old 03-23-2009, 06:10 PM
LMP's Avatar
LMP LMP is offline
Re: 96 front struts squeak
Just in case the souce of this noise is not positively identified, check the rubber bellows that slide on the tie rods...mine slide by small increments and make a rattling noise.
If the top mount is indeed the culprit, the replacement is done from under, and the entire strut must be taken off..that's overkill...I do not know is some form of lubricant can be squeezed in from under or from the top.....
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 03-24-2009, 07:40 AM
yellowfiero yellowfiero is offline
Rubber bellows on the tie rods? I just replaced the outer tie rods and I didn't see any bellows - did you mean on the inner tie rod end toward the steering mechanism?
Old 03-24-2009, 07:53 AM
LMP's Avatar
LMP LMP is offline
Originally Posted by yellowfiero View Post
... did you mean on the inner tie rod end toward the steering mechanism?
..mmm...I talked from memory...your interpretation is surely right...I'll go for a picture ..ahh yes, this bellows covering the inner tie rod end on both ends of the steering rack,
www.avigex.ca/xport/steering3.jpg
the bellows first sticks to the tie rod ; when turning the steering it then compresses (expands) depending on side, and suddenly slips, sticks again...and repeats....that makes a low frequency pulsating sound. it comes and goes with rainy and dry days....I do not remember if that occured before i changed the inner tie rod ends....i'm not sure if there was a collar over the bellows small end and if I reinstalled one or not....or let it too loose....I suppose then that there might be a risk of water intruding into the bellows....I'm just thinking I should pay a second attention to that issue.... or maybe if it is natural for this bellows to slip on the tie rod end rather than going for full expansion/compression and then eventually crack open..which would be even worse ....
Old 03-24-2009, 09:06 AM
The squeak is definitely from the top of the struts when turning. Is it a concern? thanks
