Changing a front light
Prospective Lucerne buyers or duped owners like me, in order to change a front directional light or low/high beam in a Lucerne, you have to REMOVE the BUMPER to get the light assembly out. Inaddtion to the bumper, the grill, and inner plastic fender need to be removed, and various other components. They seem to have started with the headlights, and built the car around them.
I have the instructions in Word format but have no clue how to post it. PM me if you want it and a way to get it to you. I HATE this car. Last edited by polarzak; 03-31-2009 at 06:57 AM. |
Re: Changing a front light
If you are only changing the bulbs, you are going about this the wrong way. You do NOT need to remove all of the above to replace a head light bulb.
Remove either the LF or RF headlamp capsule assembly. Refer to Headlamp Replacement. 1 Front Side Marker Lamp Socket Tip Twist the socket a quarter turn counterclockwise in order to remove. 2 Front Side Marker Lamp Bulb Tip Pull the lamp bulb straight from the lamp socket. 3 Daytime Running Lamp Electrical Connector Socket Tip Twist the socket a quarter turn counterclockwise in order to remove. 4 Daytime Running Lamp Bulb Tip Pull the bulb straight from the socket. 5 Front Corner Lamp Bulb Socket Tip Twist the bulb socket a quarter turn counterclockwise in order to remove. 6 Front Corner Lamp Bulb Tip Pull the lamp bulb straight from the lamp socket. 7 Headlamp Bulb Assembly Electrical Connector Tip Disengage the connector prior to removing the bulb socket. 8 Headlamp Bulb Assembly (Low Beam) Caution: Refer to Halogen Bulb Caution in the Preface section. Tip Disengage the connector prior to removing the bulb socket. 9 Headlamp Bulb Assembly Electrical Connector Tip Disengage the connector prior to removing the bulb socket Please don't complain about things you are unfamiliar with. |
Preliminary Procedures • Remove front compartment sight shield. Refer to Front Compartment Sight Shields Replacement . • Remove the front retainers from the wheelhouse liner. Refer to Front Wheelhouse Liner Replacement . • Remove the front air deflector. Refer to Front Air Deflector Replacement . 1 Front Fascia Bolt (Qty: 2) Notice: Refer to Fastener Notice in the Preface section. Tip Access the bolt through the wheel opening. Tighten 10 N·m (89 lb in) 2 Front Fascia Nut (Qty: 2) Tip Access the nut through the wheel opening. Loosen nut to allow stud to slide in keyhole slot in the fender flange. Tighten 10 N·m (89 lb in) 3 Front Fascia Retainer (Qty: 2) 4 Front Fascia Retainer (Qty: 2) 5 Front Fascia Procedure 1. Disconnect the fog lamp electrical connectors. Pull out on the fascia to release the tabs on the energy absorber to the impact bar. Energy absorber is attached to the front fascia. 2. With an assistant, pull fascia forward to disengage front fascia reinforcements under headlamps and allow extraction of studs from keyhole slots in the fenders. As you say, you have to remove the "headlight (capsules??)", I assume you mean the headlight assembly, and the ONLY way to do THAT is to remove the bumper fascia as outlined above. That is why they do not even tell you how to change a front bulb in the owners manual. It is a dealer item. I HAVE changed the headlights in my Lucerne, and this is the only way to do it. IF you have tiny little hands like a 10 year old little girl, you might, just might, be able to reach up from the bottom of the vehicle and change the low beam only. Still you have to remove the bottom air deflector, and will risk damaging the halogen bulb. There are a couple of shortcuts: You do not need to remove the entire wheel housing. Simply remove the four front plastic clips and you can pull the housing back to get at the bumper fascia to fender bolt. You do not have to remove the bumper fascia completely.You do not need an assistance to help remove it, as it will hang loosely enough to be able to pull it back and remove the headlight assembly GM allows 0.8 HR to change one bulb under warranty. michtom, please do not provide false information or pretend to have useful information when you do not. Last edited by polarzak; 05-19-2009 at 12:47 PM. |
