Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-23-2009, 01:04 AM
darkhorse13 darkhorse13 is offline
Chevy 350 oil pressure problem
I'm using a 80-85 chevy 350 engine in a custom car I have built. It was completly rebuilt. Its pretty much standard, except for headers, proformance, intake manifold and carb. I recently tryed to start it several times and it would only run for about a minute or less and stall out. I adjusted the fuel pressure because it was low but it made no difference. Well after starting it about 10 times I started to get a very loud screetching sound. I dropped the engine and discovered a lot of metal in the oil. I removed the intake manifold and the valve covers to discover that it was very dry. I think I had no oil pressure? does anyone know why this might be? Everything is new on the motor and it was rebuilt by a pro company, I couldn't find any obvisous sighns of failure.
Old 04-06-2009, 10:30 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Chevy 350 oil pressure problem
Unfortunately, I'm guessing your custom car didn't have an oil pressure gauge so you could catch this problem prior to disaster. There can be a few reasons why you didn't have any oil flow, and all of them should have been mitigated by the engine remanufacturer when they did the work...with the possible exception of actually not adding the oil in since engines have to be shipped dry per federal regs, but a good reman will fill it, prime the oil pump and engine, then drain it prior to shipping.
Possible problems could be a blocked oil passage (maybe from a slipped, flipped, or incorrect head gasket), mispositioned oil sump, or bad oil pump. The engine should have a warranty on it...I think it's time you exercise it.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 04-07-2009, 01:14 AM
Torch Torch is offline
On the Chevy Small Blocks the gear on the end of the camshaft drives the gear for the distributor which has a male flat slot on the end of it that drives the oil pump, you should be able to pull the distributor out and inspect where these three parts all work together without voiding any warranty the engine has.
But I also agree with darkhorse13 that you should exercise the warranty on the engine.
Old 04-07-2009, 03:44 AM
big dwag big dwag is offline
Sounds like a crank bearing has spun, Bad oil pump, bad set of lifers.
