Old 03-21-2009, 07:07 AM
bobby 815 bobby 815 is offline
confused
I just bought a 98 cav. and a light came on says ets off whats this mean,is it a serous prob
Old 03-21-2009, 11:40 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: confused
ETS is the electronic traction system. It reduces engine power when wheel spin is detected, increasing the available traction. It comes on any time the ABS and/or SES light(s) is/are on. If one of those lights is on, check the codes and we'll go from there. There is also usually a button that allows you to turn the ETS off manually. Usually on the shifter/center console. The "ETS off" light comes on when the button is pushed too.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
