A4 Keyless entry
Hey everybody, I'm new to the forum, so I'll try to keep this simple. I just bought my 16yr old daughter a 97 A4, I bought the keless fob and the dealer programmed it in two seconds, but the horn and lights don't sound or flash when I lock the car. Lights flash when I unlock it. Is there a fix I can do for this or is it back to the dealer as the only option? Ordered owners manual hasn't arrived yet. Thanks in advance for any help.
Re: A4 Keyless entry
i would go back to the dealer, there is only one way to program the keyless entry, there might be a bad connection the box that controls, i would have them go through it, the previous own could of messed something up screwing around with the car, im sorry i couldn't be of more help
<a href="http://enjukuracing.com/index.php?ref=18&affiliate_banner_id=5" target="_blank"><img src="http://enjukuracing.com/affiliate_show_banner.php?ref=18&affiliate_banner_ id=5" border="0" alt="EnjukuBanner2"></a> |
1. Put one key in the ignition, and turn to "On", dash lights lit, but car not running. Get out and close the driver's door. Might not be a bad idea to roll down the driver's window, to ensure you don't lock yourself out (you can't really, but it does give some peace of mind)
2. Put the other key in the driver's door lock. 3. Lock the car with the key in the driver's door. 4. Press both buttons on the first remote until car unlocks. This should take about 5 seconds. 5. Set the remote aside, and select the next remote. Note: Do NOT turn the ignition off between remotes. 6. Lock the car again with the key in the driver's door. 7. Press both buttons o*n the next remote until car unlocks. 8. If you have more than two remotes, repeat 6) and 7) with each succeeding remote until done. 9. Turn the ignition off and remove the key. 10. The remotes should now all work. They should each lock and unlock the car.
Replacement keyless entry remotes available here - up to 90% off - All makes/models from Acura-Volvo, 1988-present - http://www.OriginalKeyless.com |
It can be opened by the professionals only related to Audi.
Audi Q7 2008 Audi Performance Chip |
