Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 03-20-2009, 04:23 PM
dh271 dh271 is offline
Send a message via AIM to dh271
Fuel gauge part name
My fuel gauge was not working for a while. My fuel pump went bad a couple of months later. I replaced my fuel pump but the gauge still doesn`t work, It does move but in the wrong spot. What is the name of the part in the instrument cluster for the gauge and is it replaceable or do I have to replace the instrument cluster altogether?
Old 03-20-2009, 06:09 PM
stuzman stuzman is offline
Re: Fuel gauge part name
Are you sure the sending unit is okay? I don't see any mention of it in your post.
Old 03-20-2009, 07:25 PM
I installed another fuel pump, isn`t the fuel sending unit in that?
Old 03-21-2009, 10:47 PM
At one time with GM in the past, you had to buy the entire assembly, pump and sending unit. Now, you can buy each unit separately or as a complete unit. When I replaced my sending unit, I just replaced it and not the pump.
GM mentioned awhile back that too much sulfur in gasoline can hurt the sending units. Since there were a lot of failures, they decided to allow customers to buy only the sending unit.
If you did replace the sending unit, you could substitue a variable resistance, (not sure of value) to see if the gauge works correctly. Most of the time when the gauge starts acting up, 9 out of 10 times, it will be the sending unit. Do you have a wiring diagram for the car?
Old 03-21-2009, 11:07 PM
It was all one piece fuel pump. Sending unit is in the fuel pump isn`t it? When I replaced the fuel pump, sending unit would be a part of it already, correct?
