Old 03-18-2009, 05:29 PM
CL8 CL8 is offline
Check engine light questions
One of the emergency maneuvers I have our drive students perform is having the car "stall" in the middle of a turn.
I take them to a quite road or large parking lot, have them start into a turn at normal speed (about 10mph right turn, 15mph left turn) as they start the turn, I turn the key to shut off the engine. they are to continue to turn until almost straight (to see how it feels to steer with no power steering) then push the gear in neutral, restart, pull it back in drive and lightly step on the gas.
Recently one of my students stepped on the gas, very hard, in neutral before he put it back in drive. We did the maneuver a second time and he did the same thing. The Check engine light came on immediately as he pushed the accelerator in neutral the second time.
I know doing that triggered the light, I told him not to worry about it, we ended the lesson about a half hour later, I figured the light would go off before the lesson ended, it didn't go off until 2 days later.
The vehicle is a Toyota Echo
My question is,
1.What exactly was happening in the engine when he did that, to set off the light?
In training I was told when the Check engine light comes on it means the computer senses too much pollutants coming from the exhaust system.
2. Is that correct, and is there a difference between the check engine light and the emissions warning light?
3. Why would the light have stayed on for two days after that?
Thanks for any input,
Cl8
That if thou shalt confess with thy mouth the Lord Jesus,
and shalt believe in thine heart that God hath raised him from the dead,
thou shalt be saved.
For with the heart man believeth unto righteousness;
and with the mouth confession is made unto salvation.
Romans 10:9-10
Old 03-18-2009, 09:15 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Check engine light questions
anything emissions-related will set the light, although the umbrella of what is considered "emissions-related" is very broad.
depends what code was set. Some codes are "hard codes" and will not turn off until reset. Other codes are retested and will shut off on their own. But your code seems to be a hard code.
Different manufacturers do it differently. I've seen similar situations set a MAF out of parameter code on GM's, but whatever it is, it isn't really important. Just get the code reset and you'll likely be fine.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 03-19-2009, 02:12 AM
CL8 CL8 is offline
Thanks UncleBob.
Since I haven't seen the light come on again I don't think I need to reset the code.
If anyone else can explain how pushing on the gas in neutral triggers the engine light that would be great!
cl8
Romans 10:9-10
Old 03-19-2009, 06:35 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
You really need to get the code checked to determine what the likely reason was. Maybe the Echo has a code for "engine overrev occurred" or similar. Many of the chain auto parts stores will read the codes at no cost. Even though the light is currently not illuminated, there will still be a stored code. It might be a manufacturer-specific code that the parts store won't have a definition for, but in that case you could post the exact code number on the appropriate forum and expect an explanation.
-Rod
Old 03-20-2009, 10:01 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
cl8
Maybe the engine has knocked.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 03-23-2009, 01:39 AM
CL8 CL8 is offline
-Rod
Thanks, maybe I'll go to the Napa Auto Parts store near me and have them read it.
Romans 10:9-10
