Old 03-27-2003, 02:22 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
Bad situation, need advice (pretty long)
I'm in pretty bad situation, I painted my galant vr-4 body Tamiya pearl white and it was perfect. when I decided to o the black trim around the windo lines, the tape leaked through at the corners of teh trim, I tried to wipe it away with a wet cloth, carefully not touching the newly applied trim paint, and it caused a big smudge. the body wwas ruined, it had black smudges on BOTH sides (mistake happened twice). I decided to put it in brake fluid, after about 3 days I took it out, the clear in the paint came off but the pearl was still there and so were the smudges. I put it back in the brake fluid and after I week, same thing, most of the paint was still stuck to the body, ad theres even these little specs and crap on it. I thought about putting it in the brake fluid for a month or 2 months, bu I did that with my integra and teh primer came off after about a month, and I used a 1/3 of a can of Tamiya primer on this galant and I don't want it to go to waste by having it takin off by brake fluid.
I thought about e-mailing HLJ.com and ask for a new body, and pay but I have to start all over. The paint won't come off!!! Even if the paint comes off, it'll take the primer with it. Please help, maybe you have an idea that I hav'nt thought of yet.
Old 03-27-2003, 02:32 PM
RaceMySS_454's Avatar
RaceMySS_454 RaceMySS_454 is offline
Send a message via AIM to RaceMySS_454
try
Try wet sanding it with heavy than light sand paper over and over till the paint comes off i know its alot of work but hey.....its worth it..
-RaceMySS
Remember....if it has to do with Woman,Wings,or Wheels...theres bound to be trouble.
Old 03-27-2003, 02:35 PM
integra818's Avatar
Re: try
-RaceMySS
I did, forgot to mention, sorry. Thanks for your advice though.
Old 03-27-2003, 02:36 PM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
is the brake fluid new, or have you used it before? In my experience, brake fluid is only good for stripping two models.
Old 03-27-2003, 02:38 PM
njh njh is offline
Maybe you could try using compund and do some hard rubbing on it. I ever used a compund and accidently rubbed too much, and the paint job came off.
Old 03-27-2003, 02:39 PM
integra818's Avatar
Oh, I did'nt think about that, it's been used a coulpe of times, well acctually alot of times, but it's still like new because it's been filtered before putting the galant body in it.
Old 03-27-2003, 02:46 PM
integra818's Avatar
Normal paint would'ev came off with the brake fluid, new or old, a week in brake fluid would'ev taken that paint off easily, I'm not sure if polish will take it out. Thanks though.
Old 03-27-2003, 02:55 PM
daggerlee's Avatar
A new can of primer would cost less than getting HLJ to acquire you a new body. I don't think you'll be removing the paint without removing the primer first.
Dan
Old 03-27-2003, 03:13 PM
integra818's Avatar
Tamiya white primer cost $7 here, I assume hlj would sell the body for less than $7 on a kit that cost $11 . Trust me, I thought about that
Old 03-27-2003, 04:00 PM
phatmitsu's Avatar
phatmitsu phatmitsu is offline
Send a message via AIM to phatmitsu
try some castrol super clean it is hands down the best paint stripped.. Also brake fluid attacks plastic and makes it brittle.. There have been a few posts about that here.. The super clean is cheap just be sure you were some gloves with it.. Later Rick S
Old 03-27-2003, 04:11 PM
bah humbug's Avatar
That is too bad. The same thing happened once to my s2k. Rubbed the bleeding black paint out with automotive compound and walah! Fixed the problem.
But of course was not able to keep looking at the orange peel on the body and I couldn't stand it! I repainted, oversprayed and the S2K ended up in brake fluid.
Well too bad. :bandit:
Old 03-27-2003, 06:43 PM
BaNe BaNe is offline
Ditto CSC was the best.
Fender Bender - Need Advice on Repairs Panken202 Grand Cherokee | Grand Cherokee SRT8 3 10-24-2010 09:50 PM
Bad Accelleration!!!! Need Advice!!! didi575 Malibu 5 05-14-2007 04:38 PM
caprice sleeper wagon -need lil advice (lil long) flip1ky Caprice 5 03-16-2005 11:32 PM
Help!! I need advice on a situation!! joedirt76 Stress Release 14 01-11-2005 03:44 AM
New To 88's. I Very Badly Need Advice. asd Eighty Eight 6 08-19-2004 11:56 PM
