97 e150 no lights
I have an e150 van. NO LIGHTS. When I turn my van on I get NO HEADLIGHTS, but everything else works. Turn signals, raido, inside lights, brake lights and parking lights. They all work. What can be the problem?
Re: 97 e150 no lights
Welcome to AF! My lights went out on my Escort. No low beams. I thought the fuse might have blown for the L and R light but the fuses were all right. I had high beams. Turned out the L and R low beams burned out at the same time. So check to see if you have high beams.
Check headlight fuses and relays, and wiring.
Most likely the dimmer switch.
I had the same issue of having no lights. It was the dimmer switch/turn signal/wiper control unit that had to be replaced. Worked perfect after. |
