Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 03-17-2009, 12:52 AM
k0tick77 k0tick77 is offline
2002 eclipse electrical problems!
hi i have a 2002 mitsubishi eclipse that i tried to install an aftermarket cd player in, however it dident work so i went to put the stock cd in and now that wont work, i also lost most power in my car. the sunroof wont open my doors wont lock unless the cars on, my dash clock wont work, my back wiper wont work and of course th cd play wont even turn on or light up. im lost at what to do i checked all the fuses and there fine! does anyone no anything that could help me? id appreciate it. THANKS
Old 03-17-2009, 01:11 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 2002 eclipse electrical problems!
Were you cutting and splicing wires when putting the new one in or something? I don't really see any reason for so many problems unless that is what you were doing and happened to cross some wires that you shouldn't have... Possibly fried some relays?
**EDIT**
Did you disconnect a ground somewhere? It sounds like there could be a central ground for several things that isn't connected...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-17-2009, 07:39 AM
RahX RahX is offline
Check all your fuses, there are several that feed those circuits that go to the radio.
Old 03-17-2009, 05:11 PM
i accually dident cut or splice any wires and all the fuses have been checked.. the grounds are fine too.. it is possible that the wires may have touched accidently but im not positive of that so idk.. and wouldent that have just blown a fuse? its just very wierd that so many things dont work all because of one thing?
**EDIT**
Old 03-18-2009, 07:11 PM
Did you check with a test light or your eyes? You should check both sides of the fuse with a test light to make sure it isn't blown. Make sure you look under the hood and the dash.
Old 03-18-2009, 07:17 PM
I checked with my eyes but ill try with a test light. another thing im only checken the little fuses what are the little like boxes fuses? and could it possibly be those?
Old 05-25-2009, 02:29 PM
Jkudo12 Jkudo12 is offline
Lightbulb Re: 2002 eclipse electrical problems!
I'm actually having the exact same problem right now. I was gonna make a new post about it. I tested all the larger fuses with a tester light from the local autozone; all green on the larger ones but no luck getting the smaller fuses tested. I got no door locks unless its on, that orange display wont turn on, my radio has no power, no dome lights, no accessory area lights, and no HUD needle lights. All I did was try and take out my head unit and kaputz
