Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-16-2009, 07:28 PM
GAWKY's Avatar
GAWKY GAWKY is offline
Send a message via AIM to GAWKY
blower motor?resistor?
I got a 97 SL and when i have the fan on it will occasionaly change speed by its self, I checked the voltage at the blower motor and in high speed I got normal readings, when i checked the voltage it was working fine though. Could this be the blower motor or resistor going out? or could it be the fan switch??
Thanks
Old 03-17-2009, 11:59 AM
saturntech's Avatar
saturntech saturntech is offline
Re: blower motor?resistor?
Does it do it on all speeds or just on high???
Old 03-21-2009, 10:25 AM
GAWKY's Avatar
it does it at any speed, and all the speeds seem to blow at lower speeds than usually
Old 03-22-2009, 02:46 PM
saturntech's Avatar
Well it wouldn't be the resistor, because if the resistor went then you would only have high since you don't need resistance in high speed
