tips on getting gas tank off
first put the car on ramps or jack up the back, spray the gas tank straps down with a good penatrating oil every few hours for a day or two.
next day put the front of the car on ramps and remove the exhaust from the exhaust manifold. now lower the front and put the back in the air. remove the exhaust from all the hangers and remove it by sliding it out from the back of the car. you can try to remove the gas tank bolts but if you live in the snow belt best bet is to just cut the straps. unhook all the hoses and wire connectors then lower the tank the rest of the way. if you had to cut the straps now is a good time to use a grinder to grind the bolts out. anyone with other tips on getting the gas tank out feel free to include them
1999 Purple Plymouth Neon SOHC Automatic Bought Feb 2009 For $700 125,000 miles Maybe the world record for car with most hidden zip ties
Re: tips on getting gas tank off
What make/model/year car are you referring to? Or what year LeSabre?
car i worked on was a 1995 lesabre sorry forgot to include that.
I did my 97 with a full tank of gas ($4.00 Gallon plus then). Bolts came out fine. Didn't cut the straps. Didn't touch the exhaust manifold. Just took the nuts off and moved the muffler over a bit.
Chris.
1998 Buick Park Avenue (best car GM ever made) Buick Lesabre 1997, 191,000 152,000 - Motor R.I.P. Used 111,000 Motor, All New Gaskets Used 102,000 Transmission - SOLD New Balance 662 Trek 8000 |
I sugest to change sending unit because it a pain getting the hosees off and it will be alittle rusty the pipes will break or leak after support both frt and back of car remove pass rear tire to get to the fuel lines good luck there un plug sending unit . remove the hose clamp from the tank side of filler neck support tank with jack un bolt straps tank will drop down to the back of car first i have done a bonniville and my 92 lasabar if yourchanging the sending unit it is best to braek the pipes then get the hoses off good luck
I appreciate the tips. I'm hoping not to have to go that route. This car is clean so I'm guessing taking bolts out will be the procedure and not having to cut the straps. I'm working all week and won't get to the car. The thing starts everytime now so there isn't any codes displayed. I will get the pressure checked and take it from there. Thanks again.
Rob |
