Old 03-16-2009, 04:40 PM
hellah fresh's Avatar
hellah fresh hellah fresh is offline
1994 f250 5.8L idle surging...
I have a 1994 f250 5.8L and the idle surges up and down randomly. We checked the map sensor it is ok... tried installing another spare IAC sensor and its seems ok i think. Changed out the battery... what can be causing this. It will idle normal for about 5 minutes then idles up and down like crazy. What gives?
1996 Mitsubishi Eclipse RS -Red ****UPDATE**** My car is no more! R.I.P. 12/12/05
Mods: 420a DOHC equipped with: bored 54mm throttle, 2.5" cold air intake, 2.5 chrome headers, 2.5 Down Pipe, 2.5 resinator, 5" 2.5 flared muffler, 2.5 custom piping, Megan front & rear strut, Megan rear lower tie rod, Monroe Shocks, Aerospeed coilovers
Rollers: 18" TSW Throphy / Pirelli P7000 225/40/18
Old 04-09-2009, 06:59 AM
mr tiler mr tiler is offline
Re: 1994 f250 5.8L idle surging...
1992 f250 5.8 efi ex ambulance when idling does same. ive replaced the o2 cencor, idle moter callak converter. when aircon is on idling is fine , when tempreture is over half way three quaters iddle is fine. The auto electrician cant work it out.
Old 04-16-2009, 02:50 PM
LoseDevil's Avatar
LoseDevil LoseDevil is offline
Is there a MAF(mass air flow) on this motor? I had a 4.6 with similar issues and all that was needed was to clean the sensor in the MAF.
Old 05-03-2010, 12:49 PM
jardine jardine is offline
I just started having this surging issue this weekend. Any ideas on $ estimates to have it fixed? Not something i can do myself unfortunately. Also - what if I don't get it fixed? Looking to get rid of this truck soon so don't want to put $$ into it but don't want to risk a full breakdown either....can I get by with it doing this for awhile?
Forgot to add - I have the 94 f-250 5.8L also......
Old 07-23-2010, 08:40 PM
danminn danminn is offline
unplug speed senser on trans on rt side should help idle if does replace
Old 07-25-2010, 12:22 AM
builtf250tuff builtf250tuff is offline
also make sure ground connections on block are good and test ur powerpack or distributor which ever u have
Old 07-25-2010, 02:46 AM
thanks i will give it go see what happens. Ill let you know if it works..Hope it does,thanks.
