Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-15-2009, 06:39 PM
Trajansdaddy Trajansdaddy is offline
Question Engine stumbles on accleration
1994 Pontiac Transport: Engine starts and idles great but when put under load it misfires and misses out horribly! Im lost. Ive replaced plugs and wires. It has new ignition module and coilpacks. New Crank position sensor. New fuel pump and filter. What else could there be????
Old 03-15-2009, 07:25 PM
yellowfiero yellowfiero is offline
Re: Engine stumbles on accleration
Any codes?
Old 03-15-2009, 07:40 PM
No codes I cant hook up reader the plug is busted
Old 03-16-2009, 02:35 PM
I had a similar problem that went back to the PCM. Is there a way you can swap that out (if you have a spare?)
Old 03-17-2009, 11:43 AM
Whats the PCM?
Old 03-17-2009, 01:23 PM
vesamaan vesamaan is offline
Whats the PCM?
Powertrain Control Module=computer that controls everything. Located under passenger side dashboard, under kick panel.
Old 03-18-2009, 07:38 PM
yep, pretty easy to swap out.
