Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-15-2009, 02:35 PM
krunt krunt is offline
Tahoe rear
Threw the driveshaft and had a shop replace the rear yoke on the axle now it sounds like a bearing growl when I press on the gas only. It drops off when I let off. Annoying as heck. I did get the u-joints replaced but it's still there. Is it the bearing by the yoke?
Thanks
Old 03-20-2009, 09:49 AM
j cAT j cAT is offline
Re: Tahoe rear
Thanks
this diff was not shimmed,,,or incorrectly shimmed...
the diff will soon fail..
Old 03-29-2009, 03:08 AM
pear69 pear69 is offline
Re: Tahoe rear
The bearing by the yoke is the pinion front bearing. It is common for this bearing to have problems. It is best to get a bearing kit for your differential and have it installed. Be sure that there is a NEW crush sleeve in what ever kit you buy.
Old 03-29-2009, 09:33 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Tahoe rear
Thanks
What was bad on yoke?
Was the yoke put on right with proper torque?
For rear end noise.
Good flow charts on noise.
http://www.differentials.com/install.html
Post back how it goes.
MT
Old 03-30-2009, 08:02 AM
Re: Tahoe rear
My guess is that when it threw the drive shaft it twisted off an ear. then i guess the mechanic cranked on the yoke nut and crushed the collar.
Old 03-30-2009, 01:41 PM
Re: Tahoe rear
Or, the mechanic didn't tighten the yoke enough. If the diff. carrier was not removed from the case I doubt it is the shims in the rear. The pinion bearings are either loose or bad. This will will happen when the pinion nut is removed (as when the yoke was replaced) and the pinion bearing load (or torque) is removed from the pinion bearings. The load must be properly reset when reinstalling the yoke. If you keep guessing and run it with this "bearing growl", the ring and pinion gears will eventualy bind up and you will become a gear lube artist - painting a beautiful stripe of gear lube down the street. The pinion bearings should (at least) be checked - I would just replace them.
Old 03-30-2009, 05:07 PM
Re: Tahoe rear
this repair was not properly completed ....yes the torque must be correct on the yoke nut ...but the rear diff needs inspection for any shimming or damage....I'm assuming the axle snapped off which most likely did damage to the rear diff componets...
