Old 03-15-2009, 01:56 PM
jonnyblazer77 jonnyblazer77 is offline
Red face 98 Taurus fluctuating Idle
I have a 98 3.0 LX and when at Idle it stats at 1000rpm then jump up to 3000rpm then down to 500rpm and almost dies but never does, then back up to 3 and so on, also recently when driving it will also feels like it is trying to rev up a little. I changed the spark plugs and checked the vaccume lines and I am wondering what is next. Any help would be awsome.
Old 03-15-2009, 03:16 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 98 Taurus fluctuating Idle
Could be a dirty or failing MAF or dirty or failing IAC. You should try searching the forum for those two items to research symptoms others have had and what they've done to remedy them that worked.
-Rod
Old 03-15-2009, 11:19 PM
DonWontheLibra's Avatar
DonWontheLibra DonWontheLibra is offline
Sounds like you need a new throttle position sensor or possible air bypass valve.
Last edited by DonWontheLibra; 03-29-2009 at 12:11 AM. Reason: left out an option for repair
