PCV Catch Can Install
Hey all,
Just wanted to share some pics of my PCV catch can install- they on my Webshots page at http://good-times.webshots.com/photo...01767595XuGacf. Though the weather up here in the North Country is warming up slightly, there's still oil being deposited in there. It's an attempt to keep my intake cleaner, as I cleaned out the EGR ports in the upper intake last year. All that oil that's being caught would normally go through your throttle body. I got a good look in there a couple weeks ago when I replaced my coil, and all the oil in there ticked me off. After all, it was squeaky clean after I did the iso bolt job last year! Just the thought of ANY oil in the intake kind of rubbed me the wrong way after the nasty oil mess I cleaned up doing the iso bolt fix. So I did a bit of research on here and through Google, and came up with a simple solution. I think it cost me maybe 20 bucks. Some details are on the webshots page, but if you need more info, I'm here. |
Re: PCV Catch Can Install
I too installed one like you. It collects about 1/2" of milky, oily gunk and I'm really happy that it doesn't end up in the intake. Watch that your rubber lines don't flex or collapse. I've found that I had to make sure they don't get pinched too when the van hood closes.
----------- 2000 windstar 3.8 2010 honda pilot touring Muskoka Canada |
Hey Piper- I think I saw your pics of your PCV setup when I was doing my research. Thanks for the help if that was you! I'm pretty confident that my lines are pinch-free, as I checked where the hood drops to and the lines seem clear. I will keep an eye on the collapsing issue, though. Thanks for the heads-up!
My only concern with your setup is the size of the catch can.
I cannot see from the picture how big it is. I have a Greddy catch can......it is hard to tell its size from this picture. http://rides.webshots.com/photo/2194...11220610sMWSny The PCV line is in the REAR valve cover on my '96.....so my hose routing will be different than yours. I like having long lines.....and a large dead air space that is provided by a large catch can. Mine fills up in a hurry in the cold winter weather with a lot of water........but very slow in warm weather. Another step in keeping the intake clean is to use ONLY a Genuine Motorcraft PCV valve as some of the aftermarket units may not meter the correct air flow. You do NOT want to reduce the air flow from the FORD designed....better some oil than to not have enough flow....which would result in your oil breaking down sooner.....sludge...etc.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
I've been using the same catch can now since October 2008. I'd assume that winter would be the toughest test and it seems to be ok. I've drained/cleaned it 2 times since then (at oil change mtc) and like I said earlier, there was about 3/4" of gunk. Unfortunately my wife, the van primary driver, does fairly short trips so the van would be generating more of the gunk vs a longer driving period. I think the can is big enough personally but you do need to watch the volume building up. The other thing to watch is the little drain valve on the bottom of the can. It's too loose in my opinion and I ended up zip tying it in the closed position so that it wouldn't accidentally get bumped or vibrate to the open position. You may want to check yours out Dekeman. If my pix helped I'm happy. No sense reinventing the wheel
![]() Piper
Thanks, Wiswind. I'm not too concerned with the size of the can itself- it'll hold about 4 oz. and I've been watching it pretty closely since installing it. I opted for a shorter run of the lines to approximate what Ford designed into the PCV system. I wasn't sure that longer runs would be better, so I kept it as short as possible (again, trying to stick close to the original length) while keeping everything out of the way. The drain valve on the bottom will stay closed by itself. I have to go in there and tug on it pretty good to let it open. I've seen other compressor filters (that's what this is) with what looks like a vacuum plug on the bottom. I've had my eye out for a bit now looking for one that will fit over that drain nipple just to dress it up and as a 'just in case'. I'm monitoring it pretty closely right now with it being new and all, but it's not putting out a lot of fluid yet.
Where can I get one of these cans?
It's actually a campbell-hausfield water drain for a compressor. You can find them in any big box store. I took the metal, gold coloured filter out of the inside to allow for free airflow. I think Dekeman did too by the looks of his pix but he may chime in to confirm.
I would recommend removing the internal filter as mentioned......it is likely to clog and restrict the air flow.
I like to leave mine alone for a month at a time. I was hoping that locating the catch can in a cooler location in the engine compartment....with longer lines....the air might cool some.....giving a greater opportunity for the vapor to drop out in the dead space in the catch can. Ideal situation is to maintain the SAME air flow through the PCV system...pulling out what needs to be pulled out.....but catching as much gunk in the catch can....keeping the intake cleaner for longer. Again....take note of the fact that the PCV valve is in the REAR valve cover up through 1998. In 1999, they moved the PCV valve to the FRONT valve cover. Keep this in mind when using the pictures linked above as a guide to installing one on your vehicle. The catch can is installed in the line that goes from the PCV valve to the intake manifold.
Yeah, I took my filter out, and the gear-like thing as well, at Wiswind's suggestion. It ensures maximum air flow and really opened things up for the oil to drop. I didn't consider the cooling properties of running longer lines to the edge of the engine compartment, but it seems to be working out well. My filter is actually a Kobalt filter from Lowe's, since Home Despot and Wal-Mart didn't carry any. I was looking for a Husky at HD since it's black and would have matched the van's color scheme. Anal, huh?
Some helpful links I used: http://www.automotiveforums.com/vbul...d.php?t=902544 (Northern Piper's thread) http://www.pbase.com/rsrock/image/33614056 (didn't use all the mounting stuff this guy suggests, but the plumbing part was extremely helpful) http://www.titantalk.com/forums/tita...out-there.html (generally helpful and informative thread) http://www.gassavers.org/showthread.php?t=290 (another informative thread) Hope this helps!! |
hi gang, happy holidays! long time lurker. have both '00 and '02 windstars. both have plugged PCV systems (k&n breather on valve cover, plug at intake) since the vehicles were new new after experiencing the oil ingestion problem, and doing the ford TSB with no change in the amount of fluid found in the PCV valve line.
so now, after leaving well enough alone, i'm deciding to hook things back up with the hopes of a) keeping leaks from occuring, b) getting more miles out of my amsoil. but before driving i'm waiting on a stage 2 www.saikoumichi.com occ. (oil catch can). question for the guys running a OCC- any concerns running 3/8" line from the ford PCV valve all the way to the can and back to the ford hose at the intake where i'll cut the factory line and hose clamp the line from the OCC? i'm concerned about the vaccum sucking shut the hose all that way? i'm considering the factory 3/8" line is high temp plastic- very ridgid. should i change the nipple size on the OCC to something larger, or is 3/8" the way to go? tia, parker |
ditto on that regarding the 3/8" line. Mine does "flatten" a bit but I've never got a code or any problem so I think it's fine. Sure collects a bunch of milky gunk in the cold weather though!
P
Sure does. Better than back into the intake though!
what quantites are you draining from your catch cans? over what duration/ period?
a "coke" can is 12 oz. (for reference). |
