Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-14-2009, 12:53 PM
timmanem1 timmanem1 is offline
Question '97 suburban fuel pump AGAIN!!!!
Hello, everyone I'm back... This is now the fourth time I have dropped the tank, to replace the fuel pump... This last one lasted 8 months.... the best so far. The wires at the connector inside the tank are burned and melted... What could keep causing this?
Old 03-14-2009, 01:04 PM
ctwright ctwright is offline
Re: '97 suburban fuel pump AGAIN!!!!
Are you sure that you are using the correct fuel pump for your vehicle, sounds like it's trying to pull too many amps than the wire has the capacity to do so, which would cause the wires to get hot and melt stuff like you said. Or maybe also the electric motor in the pump itself wasn't bad, but stuck somehow, and trying to start the vehicle would cause the wires to get hot as well. Not sure exactly, would make me kind of scared to drive that thing again till I know for sure though, being that that's happening in your gas tank. My best advice would be since you have already went through this problem before and before I would take it to the dealer and explain to them what is going on so that it could be corrected. I definitely don't like the idea of things getting hot inside the gas tank.
Old 03-17-2009, 08:55 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
You need to quit using them cheap after market fuel pumps.
Get a good AC/Delphi pump and your problems will be gone.
MT
Old 03-17-2009, 11:09 AM
2000CAYukon 2000CAYukon is offline
Also make sure the ground on the frame rail is clean and tight.
//2000CAYukon
