160 degree thermostat
I want to replace my 180 degree thermostat with a 160 degree thermostat in my 1996 cavalier 2.2. Any suggestions where I could find one?
Re: 160 degree thermostat
There isn't one specific for us. You can take one from a Chevy 350 and trim it down to fit. We've done this before.
Please don't PM me with your J-body Issues. Post appropriately in the forums, and I will toss my opinion in your thread if I have anything to help. - Thanks! 2006 Chevrolet Trailblazer 2010 Glastron GT 205XL |
Many OBDII vehicles have a code for "ECT below regulated temperature"... I forget the number, but I've seen quite a few. Just be prepared that there is a possibility you could get the SES light on if you don't alter the ECT sensor wiring (with resistors) to read about 20* higher than it actually is. If you ever take it to a shop, make sure you tell them that you did that, otherwise you might get billed for an hour of them chasing a ghost.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
I would advise against putting a thermostat below 180* in a street car. And as J-ri said if you happen to have a 195* it might be best to stick with stock to not set a code. In engine tests 180 is about the minimum you can go without drastically excellerating cylinder wall wear. Besides if you are running a 160 thermostat in cool weather the oil might not even get hot enough to fully boil off moisture. Usually oil temp runs about 35-40 degrees higher than coolant temperature. A 180 puts you right over 212 boiling point with margin to spare. I doubt you would gain much of any performance advantage with a 160* T-stat anyway.
Im curious why kchritton wants to do that. If its to prevent overheating - then its likely its time for a new radiator for the car. Radiators are consumables, like gasoline and tires - but slower. I figure once a car has passed ten years, the radiator has paid for itself, and is on borrowed time.
Good Luck anyway. |
A lot of people think it helps a lot in performance. I would tend to disagree with that, but can't prove it. The car always feels faster if you think what you did make it faster. I went with a 160* in my truck because when I'm offroading it's not uncommon for the engine to be under full load and the vehicle barely moving. In that scenario, a lower temp thermostat gives you just a bit more room to spin the wheels before you get too hot. I'm sure the radiator isn't plugged too because pulling a trailer going 75 with the A/C on it stays right on 160*. Just a matter of the fan not being able to pull enough air for the big V8.
I would have to disagree about the radiator being a consumable. I have the original radiator in my '86 truck and it just started leaking a little bit around the side tanks last year. The coolant (green) should be flushed every two years. Dex-cool they say can go a bit longer, but I say Dex-cool can be immediately replaced with non-silicated green coolant.
I would have to disagree about the radiator being a consumable. I have the original radiator in my '86 truck and it just started leaking a little bit around the side tanks last year. The coolant (green) should be flushed every two years. Dex-cool they say can go a bit longer, but I say Dex-cool can be immediately replaced with non-silicated green coolant.[/quote] I agree Dex-cool can be replace with original green and sometimes it should be. I had changed the Dexcool in my Dad's Impala (less than 4 years old and only 40K miles). It was already starting to show signs of slightly solidifying as Dex-cool seems to like to do. A couple months later the new Dex-cool is looking worse. So flushed out the Dex-cool and put Green in and now it looks real good. This Imapala is the iron-headed 3.8 with the pressure cap on the radiator. A lot like iron-engine trucks with the cap on the rad that Dex-cool reeked havoc with. It's something about not having the pressure cap on the resevoir doesn't keep air out as well and Dex-cool doesn't tolerate air. Green doesn't mind air at all. And yu can switch dex-cool out or even mix with the original green. You got to figure all the extend-life anti-freeze on the market that says it can be mixed with anything is for all intents and purposes Dex-cool too. |
I've got trans and P/S coolers on the truck, but electricity doesn't like water/mud, so I'm not going to be adding fans to it. I probably will get the biggest radiator that will fit when I replace mine in the next couple months.
