Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-13-2009, 02:23 PM
jcutietta jcutietta is offline
Headlight issue 96 ciera
Hello. My fiance has a 1996 Cutlass Ciera Sl, 3.1V6 Auto. The other day the headlights died while she was driving. AAA showed up, the guy wiggled the fuses under the hood a bit and they came back on, so she started driving again. About 3 miles from home, they went out again and wouldn't come back. As it stands, the headlights and tail lamps won't turn on, the radio won't display jack, the ABS idiot light is on, but there is heat(the fan blows as well), the fuses in the glovebox are all good, and I can't see anything disconnected. Any ideas?
Old 03-13-2009, 02:52 PM
maxwedge maxwedge is offline
A990 racer
Re: Headlight issue 96 ciera
Look at the fuses under hood the hood also.
Old 03-13-2009, 03:00 PM
Just did. They look ok, but I'm not sure how to check them. Five small boxes with wires under them, correct?
Old 03-14-2009, 08:18 AM
Mrbizness1 Mrbizness1 is offline
Swap a few of them and make sure the contacts are clean.
Old 03-19-2009, 01:50 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Get a test light or ohm meter & test the connections on the light switch itself. The ABS light on may mean there is something wrong with the ABS system, if it is on all the time, and the computer has disabled the ABS. Get the brakes checked with a brake system scanner.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
