Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-11-2009, 07:58 PM
driverodeo driverodeo is offline
Misfire causes?
throwing a misfire code, dealer couldn't tell me what it was. (worst dealership I have ever stepped foot in.) Has brand new plugs, wires, fuel pump regulator. Is there a way to test the ignition coils? Could the O2 sensor cause misfire? O2 sensor has it's own code, right? Anyway looking for ideas on parts I should test and or replace. Would appreciate any suggestions.
Old 03-11-2009, 07:59 PM
Re: Misfire causes?
95, V6, 3.2,4x4, manual.
Old 03-11-2009, 10:43 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Misfire causes?
mine was tossing a miss-fire code due to loose plugs....
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-11-2009, 10:51 PM
FL 3.2L FL 3.2L is offline
Re: Misfire causes?
Can you scan it for the exact code(s)? Pull plugs until you find a wet one. Switch coil packs with another cylinder. See if that plug then becomes wet with unburned fuel. You could also use a code reader to see if a cylinder specific miss follows the coilpack.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 03-12-2009, 08:36 AM
Andie_J Andie_J is offline
Re: Misfire causes?
I was getting the ramdon misfire codes after a new set of spark plugs. Turned out I had used to much of anti-seize or the di-electric goop on them. After half a day and alot of question, it was finally figured out. Just took them out for about the third time and cleaned them and reinstalled with a tiny bit of that stuff and all was well.Andie
O4 Rodeo, 3.2, Auto, OME's 912's, Kangaroo Chaser
05 Saab, (My two BABIES)
Assorited Pickups for the ranch
